Jamco Oil Pan Kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2013, 07:37 PM
Russell.K's Avatar
Jamco Oil Pan Kit
Hi I got a small block 350 in a 50 ford. I'm using the jamco motor mounts and oil pan kit (part code OPKSBC). The oil pump and pick up tube are screwed up. I was wondering if anyone else had a problem with this too and if a stock oil pump and pick up will work fine with this oil pan. Thanks
Old 07-02-2013, 09:24 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What do you mean by screwed up?
A stock pickup tube probably won't be the correct length in a 7 quart pan, you have to do some measuring and find a tube/screen assembly that will give you the right pan bottom clearances.
Semper Fi
Old 07-02-2013, 11:43 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Did the pickup assembly get mauled while installing the press fit tube? If so, you can make a tool that will help a LOT when it comes to installing the p-u.
That front sump pan, oil pump and p-u look similar to early Chevy II V8 parts. If you need a new p-u, I'd look to see if one for the Chevy II will replace yours correctly.
Jamco:
oil pump, small block chevy
Trans Oil in oil pan mike Crawford Engine 21 04-09-2013 07:45 PM
Will oil pan seal with one broken oil pan bolt? Dougie Engine 2 03-10-2011 09:29 PM
400 SBC oil pan question..What quart size of pan do I need? heathj1 Engine 10 07-26-2010 09:26 PM
Jamco Suspension 49 Merc Suspension - Brakes - Steering 4 09-13-2007 07:04 PM
351w oil pan/ 5.0 oil pan interchange? problem solvers Hotrodders Site Suggestions and Help 4 05-10-2006 09:36 PM
