We're winning the case!
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 10-06-2009, 10:30 PM
bobyell's Avatar
bobyell bobyell is offline
Jammin' without masking
I've just started jamming my firbird , but i didn't need to mask anything off as there really isnt anything to mask. But My friend just told me that i should have masked because the clear overspray can't be painted over sucessfully. He said i need to sand down the overspray and re-prime it. Is that true and I should mask off the area?
Bob
Old 10-07-2009, 11:12 AM
cyclopsblown34's Avatar
cyclopsblown34 cyclopsblown34 is offline
Colorsanding painter
Gently sand off the overspray and you'll be fine. If you cut through the primer, reprime the panel. You can paint over the overspray but it will result in a little texture in the final finish just by virtue of th rest of the panel having a different texture to begin with when you start spraying.
Old 10-07-2009, 06:50 PM
bobyell's Avatar
yes that was my intent , just keep the overspray to a minimum and sand it before continuing with painting.
Thank you
Old 10-07-2009, 09:02 PM
35prog's Avatar
35prog 35prog is offline
Be careful of this, I tend to agree with you friend. I have seen a lifting problem an inch or so from the panel edges. I jamb panels prior to the final sanding of the outside of the car. I sand the outer portion of the panel back a couple of inches for adhesion. Then sand to the panel edge when I final sand. I look at it this way... You will be sanding the "overspray" clear off anyway if it lifts. A paint guy told me this was happening due to the lack of mill thickness was not allowing it to cure fully where it was lifting.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Jammin' without masking"
3M masking tape onebadmerc Body - Exterior 16 01-03-2009 06:00 PM
Another masking query northiam Body - Exterior 3 12-21-2007 11:10 AM
Can someone please explain the correct procedure for masking? northiam Body - Exterior 2 11-19-2007 11:35 PM
"Basics of Basics" Reverse masking for two tones MARTINSR Body - Exterior 0 03-12-2007 11:32 PM
Masking Door Jams etc. 36ford3window Body - Exterior 9 02-06-2005 08:17 AM
