Jaquar independent rearend ID? u-joint plate - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2005, 08:07 PM
Father-in-law just bought a 55 Ford truck frame from a "good ol' boy". It has a jag IRS in it and I need to know if there is a way to ID this. What I need is the plate that bolts to the pinion that holds the u-joints. The IRS doesn't have the typical(what I'm used to) pinion with the u-joint slots in it. It's just flat. Thanks.
Old 03-27-2005, 11:07 PM
Last journal entry: The floor going in
Try these guys i am sure they will sort you out http://www.jaggraveyard.com/
cheers stuart
measurments for a rearend 50chevyfastback Transmission - Rearend 2 10-04-2002 12:19 PM
