Jasper 305 V8 and chevy stock trans. questions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2005, 06:26 PM
Post Jasper 305 V8 and chevy stock trans. questions.
I have a 1985 Chevy 1/2 ton...4wd...auto., with a Jasper 305 V8...the transmission blew, and I was wondering if it would bolt up to my 1991 Chevy 1/2 ton 4wd, auto., transmission.? and if it would in fact bolt up...would the driveshaft...etc. be affected? I've been looking around trying to find out if this is going to work...any suggestions??
Old 02-04-2005, 06:29 PM
coldknock's Avatar
If the 4WD had a small block chevy in it the 305 should bolt right in.
Larry
P.S., you username might be a bit offensive to some folks.
Old 02-04-2005, 09:06 PM
thanks...ya I have a 350 V8 in my '91 and the '85 has the 305...but I talked to a mechanic..and he said he wasnt sure if the drivetrain and what not would all match up...but I will keep looking into it...thanks for the reply...
sorry bout the name...I'll think bout changing it.
Old 02-05-2005, 07:39 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
If he is a mechanic and don't know the blocks are the same size it's time to look for another mechanic. Here is the data site.
http://www.carnut.com/specs/engdim.html
This has been discussed before and in the Knowledge Base.
Luv the smell of NITRO in the morning.
