Jasper is very crooked! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2009, 01:25 PM
Last journal entry: not a big fan of cherry picker...
Last year I blew the motor in my RV. We decided to go with a Jasper motor because they told me for the almost $5000 dollars i paid for the motor it had a parts & Labor warranty for 18 months or so many miles. I have less than 1000 miles on the new motor. I was driving it home from Florida when the motor starts making a wicked slapping noise and shaking all over the place. Long story short ended up at a mechanic, Mechanic Says the head gaskets went due to stretched head bolts. Jaspers says they will only cover parts.
In my experience the only way to stretch head bolts is to improperly torque them when the motor assembled.... Correct? So would this not be Jaspers Fault as they assembled the motor? Now a $9400 dollar motor is turning into a $9400 motor + $2500 in repairs + the cost of the lawyer to sue Jasper.
What else would cause the head bolts to stretch??? Any advise would be appreciated as I need to be as knowledgeable as possible if I end up in small claims court suing for just the repairs... Thanks in advance.
Old 04-07-2009, 01:29 PM
DoubleVision's Avatar
Is this a Chevy engine? I`m not sure about other makes but I`ve reused chevy head bolts countless times and never had a issue.
Old 04-07-2009, 01:33 PM
Sorry... This is a Ford 460 on a John Deere chassis, with a carb.
Old 04-07-2009, 01:35 PM
Banned
Yea, Jasper engines suck- this is one of those times where askign around more would have been worth it. I worked at a shop and one customer insisted their fleet get Jasper engines- we refused to warrenty anything as they are crap. They're assembled suing the cheapest parts available.
Old 04-07-2009, 01:59 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
man that really blows, i never knew jasper was like that, being as big a name as they are, good luck with the suit, if you can sue them for the lawyer fee's as well, after all if it weren't for them you wouldn't have had to hire a lawyer so shouldn't they be held responsible for that expense too
Old 04-07-2009, 02:10 PM
I don't know what warranty language you were given at purchase, but their current warranty is posted on-line:
http://www.jasperengines.com/pdf/warranty.pdf
Note the exception for motorhomes:
"Maximum of 25 hours" lifetime.
That seems pretty short, since that's only 1400 miles if you drive a constant 55 MPH. At 50 MPH it's only 1250 miles. It DOES say that they cover parts and labor, however.
As for the stretched head bolts, I'd get a second opinion. The Ford 460 doesn't used torque-to-yield head bolts. You are correct in that if they really are stretched (and it isn't clear how you can prove that), it's a problem with the engine you got (assuming you bought a long block). How did the mechanic determine that the bolts were stretched as opposed to any one of a dozen other reasons for a blown head gasket?
In any case, it sounds like there is a big disconnect between what you may have been told about the warranty and what they say in writing as far as motorhome use is concerned.
Old 04-07-2009, 03:01 PM
techinspector1's Avatar
Wiki Edits: 326
See if you can determine the source of the bolts. Could be that Jasper used cheezy offshore hardware that had inferior metallurgy.
Old 04-07-2009, 03:26 PM
Unforuately the rv is in WV and I am back in NY... I can already sense I am gonna get this right up the you know what... end up paying for the repair and just waiting for the next time this crappy motor decided to **** the bed! My soon to be wife hates the damn thing as it is... Anyone wanna buy an RV with a fresh motor?
Jasper Engines johnc486 Engine 19 09-06-2006 09:32 PM
Jasper Engines Everett II Engine 3 09-02-2005 05:16 PM
Jasper Tranny Yoke Leak? S Dink 1 Transmission - Rearend 10 06-04-2005 11:44 AM
Jasper 305 V8 and chevy stock trans. questions. Unfckngblvbl Engine 3 02-05-2005 06:39 AM
Jasper dollybud Hotrodders' Lounge 2 04-12-2003 12:29 PM
