Javelin will not start?
I have a 1973 Javelin with a 232 6 cylinder engine, manual transmission, standard, no tilt steering column. Primary ignition uses a resistance wire. Stock ignition with points and condenser.
All of a sudden when you turn the ignition switch to the "on" position the dash lights no longer come on. The starter turns over fine, the engine acts like it is going to start, but when you let off on the ignition switch to the run position, the car dies right away. Anyone know what causes this? Thanks. |
Problem is intermitant now
I have checked everything and all seams to be well. Just tinkering around with it I got the car started but it will only run a few minutes, the alternator light will come on for a second, the engine starts to die, the alternator light goes out and the engine runs fine again. I tried tapping the wire conections and wires to check for a loose connection while the engine is running but nothing happened.
Can anyone give me an idea of what is going on here. Could something breaking down inside the alternator cause this? |
I have a 1969 rambler, the wiring is very similar to your Javelin. It uses a ford solenoid. Since the engine will fire & run with the ignition key to start, solenoid is fine. Also shows the associated wiring to the starter, points, and coil is fine. Since when you let go of the key, the engine dies, you most likely have bad ignition switch. The dash lights (I'm assuming you mean the dummy lights) are run through the ignition switch as well, further pointing to your ignition switch. The slide contacts often become brittle with age and eventually break off.
Problem gets worse
OK, I have replaced the ignition switch, found a corroded connection 6 inches from the solenoid, discovered the two wires going into the back of the alternator were loose. Fixed all I could find wrong, the car worked great for a few days after that, (thought I had fixed it) and then suddenly now when I turn the the ignition switch to the on and start positions I get nothing. The lights on the dash do not light up, and the starter does not turn. Any ideas?
Found the problem
After two weeks of checking all the wires and ignition switch I found the problem. Everything checked out OK separately, but then the car would not start. It turns out the main feed line from the battery to the ignition switch (red) had vibrated its way out of the plastic harness that plugs into the ignition switch. I pushed it in about an eighth of an inch and the car works perfectly again. I just happened to notice that wire was sticking out an little further than the rest of the wires. That whole unit is tucked up under the dash so far you can hardly see it.
Isn't it always the simplest things that will drive you nuts?
Glad to hear you found it and thanks for letting us know the solution! |
| Need help with a stubborn 4.3L V6 that won't start | Mad Maggot | Engine | 14 | 10-06-2011 11:48 PM |
| "Basic of Basics" Welding - How do I repair body panels? | Centerline | Body - Exterior | 29 | 06-18-2009 06:54 AM |
| head gasket replacement now car won't start | jesse01 | Engine | 10 | 04-28-2007 05:53 AM |
| Sometimes my car won't start | 55ford | Engine | 10 | 12-19-2004 01:55 PM |
| please help..... annoying warm start problem | 67cuda | Engine | 21 | 03-28-2003 05:44 AM |
