Jay's GM Engine Block ID
Question to you motor gods - I have what I believe to be a Chevy 350.
I have a 3970010 block with k03 22 TBC stamped on the front passenger side. I'd like to know what the engine is: Can anyone make sense of the code and suffix for me? It's a 4 bolt main, Is it worth rebuilding and what horsepower can I get out of it? |
A simple visit to www.mortec.com would have found the following:
3970010....302.....69....4...Z-28 Camaro 3970010....327.....69....2...Trucks and industrial 3970010....350...69-80...2 or 4 A simple Google search for the TBC engine code would have taken you to www.nastyz28.com and you would have found the following: TBC 1979 350 conv. cab, m/t,fed L LS9 165 4 C-10 to 2500 Your engine was a 350 from the factory with a manual transmission behind it in either a 1/2 or 3/4-ton pickup, and it put out 165 horsepower from the factory with a Federal emissions package, meaning it wasn't destined for CA. It also originally had a 4 barrel carburetor on it. It's definitely worth keeping as it's a pre '85 4 bolt main 4 inch bore small block SBC, it can be made into a 302, 327, 350, or 383- and if it hasn't been previously bored out already it can be rebuilt at least a couple times. |
More>> http://www.chevymania.com/chevymania...fm?block=Small
Code- Year- CID- Vehicle- HP-- RPO--- Trans-- Carb---- Comments ------ TBC--- 70-- 350- Truck-- 255- LS-9-- Manual- 4-Brl---- C10 & C 20, 4X4 TBC--- 71-- 350- Truck-- 255- LS-9-- TH 350- 4-Brl---- All Models------ TBC--- 79-- 350- Truck-- 165- LS-9-- Manual- 4-Brl---------------------- The Block Casting date, which is close by the Casting number will narrow the year down more. >> http://www.mortec.com/location.htm |
Thanks
Awesome info guys, thanks! Now to begin the rebuild...Any pointers.
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| 96 3.8L GM engine dies seconds after startup | 49Austin | Electrical | 6 | 11-27-2008 12:40 PM |
| 383 Recipe | Sweet Lu | Engine | 9 | 10-20-2007 12:01 AM |
| Chevy big block engine knock | Ratillac51 | Engine | 3 | 01-07-2007 03:33 PM |
| Ford Y Block Engine | RetroJim | Engine | 11 | 06-14-2006 06:37 PM |
