JB weld as body filler ? - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 04-12-2013, 10:59 PM
Originally Posted by Kevin316 View Post
Nothing to do with paint and repairs but there is a place for that "type" of filler.
I used a two part product called Epo Strong for filler on my frame and transmission housing before powder coating. Regular filler isn't conductive so it can't be used. I have thought about using it for filler in places like the firewall.
Thats a good point that its not conductive for a powdercote procedure.
  #47 (permalink)
Old 04-12-2013, 11:38 PM
Originally Posted by dogwater View Post
After using J B weld on the back glass channel I painted all the way around the channel with epoxy primer with a small paint brush. I did that because it looks like water can seep between the glass an the trim an stand in the channel, being J B weld is non-hygroscopic it seem to be the best protection from more damage. I did the same thing on the t-top channels as they were pitted also. Just wanted to be sure of having a good seal.
Good point well made sir! I agree too, JB Weld is a strong bonding and sealing product. I have used it for pin holes and small pitted ares that after properly cleaning the spots lasted forever.
  #48 (permalink)
Old 09-19-2016, 09:08 PM
Helicopter use~everywhere....
i was considering using it as a small area (less than 1 inch) instead of leading because it is near a window in an older mercedes.....I used to fly helicopters for a living and I can tell you for a fact JB Weld held all our gearboxes together....and every other place they needed it...so as far as heat and vibrations....it doesn't get anymore demanding than in flight....what say you?
  #49 (permalink)
Old 09-20-2016, 08:31 AM
TucsonJay's Avatar
I did exactly this. Had a few tiny pinholes... tapped them in... metal prepped... sanded... filled with JB weld for the strength and water-tight seal.... then sanded and covered with filler.
I only did it because of the holes, and don't expect to again.
So far no problems.
Originally Posted by kenseth17 View Post
I haven't used jb weld, but have used epoxy based adhesives before for filling small holes where didn't want to weld, and used bodyfiller over that. You have to watch though, many recommend epoxy priming first before using any bodyfiller over adhesive, but believe that is mostly urethane based stuff.
I would not consider using jb weld as a body filler, although something very similar is often done on urethane bumper repairs, using a adhesive that has some flexability for the majority of the repair, and regular filler for final finishing work.
If I was stuck on using epoxy as a filler, well then I'd probably use an epoxy fairing compound, like I've used in the when working for some boat builders (basically bodyfiller in marine terms). Its a 2 part filler as a base and convertor must be mixed together.
Haven't really seen any bodyshops using it at all. although I am sure somewhere some place might, but fairly commonly used in the marine industry.http://shop.sailnet.com/product_info.php/products_id/38 I like fiberglass filler when a bit more fill or a bit more water tight filler is wanted then comfortable using plastic filler, but would actually prefer using the epoxy filler over all metal junk that I was forced to use a whole lot of at a past job.
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
Evercoat "kitty Hair" body filler chevymastermind Body - Exterior 12 05-11-2007 05:14 PM
The most common mistakes made by the newbe working with plastic filler. MARTINSR Body - Exterior 7 02-14-2006 10:21 PM
Chop and channeling. how to....? baugh353 Body - Exterior 15 02-07-2006 07:21 AM
Body Filler Shaping Ron M Body - Exterior 2 09-29-2004 11:52 AM
