Jb weld stuff - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-30-2005, 04:41 PM
Last journal entry: frame build
Take a look at your new car. You'll find the doors are glued on as are many other stressed and structural pieces.
Burt Rutans around the world unrefueled flight was done in a glued composite aircraft.
Go ahead an glue that sucker on there. Be a pioneer and keep us posted on the results.
  #17 (permalink)
Old 10-01-2005, 11:49 PM
56f100's Avatar
I was just wondering what you guys would think of using JB weld to fill in the drip rail of a 56 F-100 as compared to led filling it.
Thanks, devin
  #18 (permalink)
Old 10-03-2005, 12:14 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
What's wrong with a good metal content body filler like "Aerolite"? Clean and roughen the metal and it should be as good and cheaper than epoxy or lead.
  #19 (permalink)
Old 10-04-2005, 12:47 PM
I think it's always good to "be a pioneer" in certain areas to better a trade practice......but.
You don't do it with JB Weld, that is not the appropriate adhesive to use. JB Weld IS NOT A THIN FILM ADHESIVE, as are the adhesives made by Fusor, 3M and others for this SPECIFIC PURPOSE.
In the body shop world, or even on the slight edge of it, using JB Weld to mend body panels is a HACK JOB that will soon fail.
Don't do it.
As for lead versus JB, no contest, LEAD. If this is an area that has flex, then you can't use filler.
More Cool Hand-made stuff Weimer Hotrodders' Lounge 10 03-05-2009 06:34 PM
e-brake bracket - jb weld - paint or no? hmn Woogeroo Body - Exterior 3 09-21-2005 08:14 AM
jb weld held jtdchevy Engine 11 03-13-2004 03:07 PM
leaking gas tank bigwildgrin General Rodding Tech 10 10-07-2003 11:14 PM
Cam lube gray-graphite stuff vs. the red stuff. 78 monte Engine 28 01-23-2003 10:24 PM
