Jeep auto trans shifting troubles - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2009, 02:55 PM
cecil671's Avatar
I have a 2000 Jeep Wrangler 4x4 and 4.0 engine with the automatic trans (3 speed/no over drive).
The trans changes gears 1st to 2nd fine but from 2nd to Drive it seems to take a lot longer to finally shift .Sometmes 3000 rpm or more.
I changed the trans filter and put in the +4 atf that is required as well as Lucas trans additive but it still act up.
It seems to shift better after everything warms up.
The trans holds well in all gears with no slipping once it is in each gear.
Any ideas before It goes to the shop tomorrow?
Old 04-07-2009, 06:27 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Is this a high mileage vehicle - transmission?
I would be looking at the TV linkage from the engine to the transmission. Broken bushing, it popped out of adjustment.
If you live in the snow belt areas , this linkage can corrode , become sticky.
Unless you have engine problems and you are stepping on the throttle harder while the engine is cold
Old 04-07-2009, 08:56 AM
cecil671's Avatar
Thanks for your reply.
It high mileage (120,000).
I will crawl under and check the tv cable.
Old 04-08-2009, 04:06 AM
Wiki Edits: 85
Chrysler 904/998/999 transmissions do not have a TV cable.
Auto Tech vs. Auto Body Career? mgold Hotrodders' Lounge 41 01-04-2010 07:36 AM
sbc aluminum 303Hp & best auto trans WangoBangoTango Engine 1 02-05-2009 08:22 AM
not a hot rod, 96 jeep cheroke laredo. trans problem chevelle4542speed Transmission - Rearend 1 07-29-2007 06:45 PM
Jeep trans 350rebuilder Transmission - Rearend 1 05-02-2007 11:45 AM
57 Chevy auto trans cross member pikalpha Transmission - Rearend 7 12-09-2005 01:02 PM
