Jeep dies, then re-starts, ideas please - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2008, 09:14 PM
i have a 91 jeep cherokee and can not figure out what the heck is up i'm driving along and it just shuts down sit for a few min start back up and then all over again till the next day or two then it will run for an hour or so then it starts all over again it will idle for ever till i touch the gas and then it dies anyway cant figure it out so please help please
Last edited by 68NovaSS; 01-28-2008 at 09:28 PM. Reason: Profanity. Please see: general board guidelines.
Old 01-28-2008, 09:22 PM
sometimes ignition modules act like that when there on there way out but not so common on jeeps
Old 01-28-2008, 09:27 PM
Had a Dodge truck that did that ,the computor had gremlins in it, after new computor it was fine. Good Luck
Old 01-28-2008, 09:39 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Chevyman420, the title of your post is borderline suggestive profanity, and has been edited.
Profanity is not tolerated on this board, please express yourself differently in the future. Thanks.
Old 01-28-2008, 10:42 PM
so i have been told that it might be a crank positioning sensor the book mentions a cam shaft position sensor(stator) but that is in the distributor and i have to tear the dist. apart or could it be the coil
Old 01-29-2008, 06:25 AM
GMC boogie's Avatar
Get a crank position sensor. Very,very common on these vehicles. Not real fun to change on some years/models.
Old 01-29-2008, 06:43 AM
forestrytodd's Avatar
Official Hotrod Forester
Had a work truck with the same problem. I replaced the crank sensor and it ran great after that.
I hate these new computer motors!!! It is hard to diagnose problems without a code scanner. They do make good gas mileage though.
Old 01-29-2008, 06:59 AM
I didn't say it
Dear 68Novass, I did not have any profanity in my post, so why the message under my post????? the other guy put it in his, but you made it look like I was bad. Ace
Old 01-29-2008, 09:11 AM
Wiki Edits: 49
The post was addressed to Chevyman420 not you. Plus when a post is added to the thread it is added based on the time it was made. Mods can not insert a post anywhere they want, it's just not possible with this software.
Old 01-29-2008, 11:01 AM
ok thanks i'll read the book a little more and see if it has one and where it is at i'll keep you updated thanks again
Old 01-29-2008, 11:10 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
You can replace sensors, and electrical parts until you are blue in the face and your wallet is empty or you can bring it to your local jeep dealership and drive it while a tech monitors the sensors. It might take an hour of labor but electrical parts are not returnable at most parts stores. So you will save money by fixing it right the first time.
If the problem is as predictable as you say it is then it will be easy to diagnose with the right tools.
Old 01-29-2008, 11:13 AM
ya thats a good idea i'll trailer it to shucks or a dodge dealer and hve them test it thanks thats a good idea
Old 01-29-2008, 12:15 PM
Wiki Edits: 49
You might want to take a look at your fuel filter. If it clogs it would give you the same symptoms. The engine will die and after a few minutes and the sediment settles to the bottom it will start and run perfectly again. Just a suggestion.
Old 01-29-2008, 12:46 PM
speede5's Avatar
go fast, turn left!
This isn't by chance happening while you are driving near the Empire State Building is it?
JK, I hope you can find your problem, a friend of mine had a 97 Grand cherokee, new, that would just quit sometimes when you would try to accelerate from a stop, usually at traffic lights. They did a ton of work too it and never could solve the issue. Through arbitration Jeep ended up buying the vehicle back.
Old 01-29-2008, 06:09 PM
Wiki Edits: 31
It can't be the Crank position sensor. jeeps need a crank signal before they will administer ignition, so if the crank sensor was bad, it would have a no start condition.
if the crank sensor goes bad during an operating period, the vehicle will begin to run badly but won't stall. a cam sensor or ignition module is a better guess.
I need ideas... BIGK Hotrodding Basics 6 10-02-2007 07:56 PM
Willys?? scott011422 Hotrodders' Lounge 28 08-21-2007 11:57 AM
paint ideas for four door 66 nova 2 merowe Body - Exterior 2 01-30-2006 12:47 AM
Jeep Question? TonyMac Engine 6 05-28-2004 08:56 PM
Jeep Transmission Question? TonyMac Transmission - Rearend 2 05-25-2004 08:18 PM
