Jeep Engine Blown - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2010, 08:35 PM
Jeep Engine Blown
drove 17k miles without oil change; engine seized and two garages struggling to find answer. any chance this can be rebuilt? Is this definitely an engine change? Are some of these online engine resellers risky, buying without a mechanic seeing it before it ships??
Old 05-23-2010, 08:45 PM
techinspector1's Avatar
Wiki Edits: 326
Ummmm, answer is, you drove it 17K without changing the oil.
Whether it can be saved or not is dependent on the damage. If a rod seized on the crank, you can replace the rod and turn the crank for undersize bearings down to 0.030" undersize. If the crank is hurt beyond that, then a crank replacement is in order.
If the crank screwed up one or more main bearings and the saddle of the block, it can usually be saved anyway by align boring the block.
As far as buying a crate motor, I won't do it. I want to measure and choose everything myself. I simply do not trust anyone. If there is any opportunity at all to cheat, somebody out there will do it. That's Murphy's Conclusion, filed right before Murphy's Law.
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 05:55 PM
750 cfm secondary vacuum enough for a blown engine? 84Z Engine 36 09-20-2004 10:33 PM
Can you add NOS to a carberated blown engine? ChrisMiddleron Engine 1 06-18-2003 05:17 PM
