Jeep mail truck straight axle question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2006, 05:23 PM
MiMAX's Avatar
Does anyone know what brakes will fit a jeep mail truck straight axle? It has 10" Drums on it now. If I take it to use it ,I want disc. OPen to sugggestions. Its free. Could make a good hot rod axle. Help
Old 04-05-2006, 10:31 PM
Depending on the year model(you are talking about the small van type) the older ones are probably some type of Ford style & newer ones are probably Chrysler products.
Old 04-06-2006, 02:57 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Depending on the year it could be a Dana 27, Dana 40, Dana 44, AMC 20, or countless others. Pictures or codes would help us identify it.
Old 04-06-2006, 05:15 AM
MiMAX's Avatar
Dana 44 etc
Dana 44,etc,Aren't all the axles all with gears in them? This has NO gears only a straight axle.
Old 04-06-2006, 12:02 PM
curtis73's Avatar
Wiki Edits: 16
Are you talking about the front axle on an older mail jeep? I thought you were talking about a rear axle, sorry.
Old 04-06-2006, 11:15 PM
Last journal entry: one more
Jeep Straight axle
I was looking at one of those today and it had a small A body lug pattern (Mopar). I would assume you could play any game the you could on an early dart/ valiant. Kind of an interesting drive line Chevy 2.5, Mopar 904, and a real small mopar Posie rearend. Good luck post what you discover..............
Old 04-07-2006, 01:21 AM
Mail to go
I would have guessed Dana 28 to 30 to 44, and 6000 others. What year, what part of the country, since its not 4x4. Rear posi Jeep has been down to many roads. Willys? If you don't know the year.Identify the engine Depending on general period Identify the rear axle Look for the numbers on top,front,rear on the passenger side tubes If not there check the other side , then inside. If you can trace the rear axle then you can hopefully use that to trace the year and the rest I would lean real heavily on the rear being Dana, or hope that it is. They used to be real helpful folks. The willys followers sometimes are great, every single part no for the entire vehicle, I hope its really old or new. let us know. mark
Old 04-07-2006, 01:25 AM
mail to go
One other question, Is the front axle solid drop axle or a tube.mark
Old 04-07-2006, 03:57 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Maybe this will help. It has a link to a few sources:
http://www.freelabs.com/~whitis/mailjeep.html
http://www.4wd.com/4wdforums/showthread.php?t=834
http://local.mebcs.com/jeep/jeep.html
Old 04-07-2006, 04:55 PM
MiMAX's Avatar
Mail truck
Front axle is tube.
Old 04-07-2006, 06:40 PM
mail
Later model, vote for mopar. mark
Old 04-09-2006, 06:17 PM
techinspector1's Avatar
Wiki Edits: 326
Here's how I'd do it.
Take one spindle and a 6" dial caliper to the boneyard with you and start measuring Mopar and AMC disc brake spindles. You may get lucky and find a match. If not, buy the closest ones you can find where the spindle is slightly smaller than the mail truck spindle. Take EVERYTHING from the hub nut cover to the flex hose. If you don't have access to a lathe, go to a local machine shop and have them machine the donor spindle to the mail truck spindle specs and also rig up the caliper mount for you. Go down to NAPA, get kits and rebuild the calipers and you're in business.
Old 04-10-2006, 12:13 AM
brakes for Ben
Benjamin Franklin-Anyway, You could be detrimentally unmatched in brake lock in the front. I drive a old pickup a lot that always locks the front wheels first, slightly dangerous, If by some fluke this happens , in a troublesome manner, gm makes parts for it, or at least will work, after market also. mark
straight front axle help 54chevygasser Suspension - Brakes - Steering 24 03-10-2005 08:11 AM
Jeep Transmission Question? TonyMac Transmission - Rearend 2 05-25-2004 08:18 PM
transverse spring & straight axle 26trackt Suspension - Brakes - Steering 3 01-18-2003 11:45 PM
A newbie question about my Chevy truck BigRed Engine 10 01-01-2003 01:24 PM
34 ford truck front axle ideas and questions lilred34truck Suspension - Brakes - Steering 1 10-30-2002 05:20 PM
