jeep runs rough after wash! bigwrench3311 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2012, 03:03 PM
1999 jeep grd.cheeroke lost inj. pulse after press. wash, any ideas? please help! thank you.
Old 09-25-2012, 03:31 PM
delawarebill's Avatar
no fire
I'd say your ign sys is not as water proof as a jeep should be.. try spray'n WD40 everywhere..
Old 09-26-2012, 01:28 AM
59RAMBLERSUPERWAGON's Avatar
Its the right tool if it works
Last journal entry: Bondo oh no!
Water in distributor, coil, plug wires etc dry it all out and move on. I don't ever spray wd40 in distributors, it causes fouling down the road.
Old 09-26-2012, 07:08 AM
Irelands child's Avatar
After an engine pressure wash, it cost me a throttle position sensor(TPS) - and I was dumb enough to do it twice. It also cost a coolant temp. sensor. You need to get a code reader plugged in to the car 'puter to tell you where you '$crewed up', not do the $hotgun approach.
Irelands child
Old 09-26-2012, 07:58 AM
First check to see if check engine light comes on when you turn the key on. If it does not you have lost power or ground to the computer. First check the fuse for the PCM. If okay unplug the Throttle postion sensor or the map sensor to see if you get a referance voltage with a digital ohm meter. This comes straight from the computer if you don't have any voltage there then you have a short in the harness or the computer is not any good. If you do have voltage then check the crank position sensor or the camshaft position sensor. If these have voltage then check the O2 sensors. Please in the future do not put water in the engine compartment.
Old 10-03-2012, 04:52 PM
4.7Liter has no dist. ect. It's mpfi. there is no inj. pulse #6 cyl.only. hope this help for ideas?
suddenly runs really rough 23 tbucket Engine 16 07-21-2012 02:39 PM
Jeep runs hot newdad1 Engine 8 06-08-2009 06:14 PM
Engine runs rough. lt1bbody Engine 19 09-13-2005 01:27 PM
Runs Rough when Cold airman_turtle Engine 6 07-21-2005 01:25 PM
