Jeep shifter for ford top loader 4 speed trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2009, 07:06 PM
Do any of you guys or gals out there have any info RE putting a jeep shifter on a F-o-r-d top loader 4 spd???? I think I'd like to put that combo behind my 8ba flatty; it has the removable cast bell hsg and a '39 top-loader trans now ( w/ a closed driveline that will need to go away w/ an open-drive conversion for the " banjo " rear end) Do you use a 3 spd shifter, using the reverse position to engage low gear then maybe a lever/cable to operate the 4 speed's reverse after putting the main shifter in neutral?? What kinda bell hsg and adapter should be used? Wow, a lotta questions for a "newby" , huh?
THANK YOU in advance.
Old 02-22-2009, 07:23 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Actually there is an easier way..Look for a ford pickup trans withe the RUG/RAT designation from an early to mid 70's pickup..those have the old fashioned top loader shifter and are 3spd with O/D have a std Ford bolt pattern and should bolt right up to your bellhousing..Found in f-150 with six cyl trucks mostly..
Sam
Old 02-23-2009, 06:04 PM
Wiki Edits: 31
Ford Granada 4spd also, is the same trans
Old 03-04-2009, 08:12 AM
I've done it
I have put a Jeep shifter in a Ford toploader style transmission. If you can find the article by Frank Oddo in the Dec.1990 Street Rodder, it covers everything. The number on top of my 4 speed Jeep shifter is C-2604208. Hope this helps! Jeff
5 speed trans My 57 Transmission - Rearend 3 05-22-2006 07:53 AM
Pro 5.0 Shifter for a GM T-56 trans - Anyone tried it?? hotrodf1 Transmission - Rearend 2 05-22-2006 07:18 AM
Trans Am 4 speed 68Velle Transmission - Rearend 4 08-25-2004 10:04 AM
small block trans to BB in a ford (4sp. top loader) pj Transmission - Rearend 2 04-22-2002 10:37 PM
