Jeep wrangler with a 5.7 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2012, 12:36 PM
I have a 1991 jeep wrangler that had a 4 cyl. I installed a 350 brand new HEI dis. The jeep runs great with the exception that it is hard to start? The engine will only fire when the ignition is released? I used the jeep wire harness and can not trace the correct wires to use. Any suggestions would truly be helpful.
Old 07-24-2012, 01:50 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
my guess
The ignition switch is not supplying power to the HEI during cranking.
Is the new 350 a computer controlled engine? More detail would be nice.
The HEI must have power during cranking. Put a meter on it to check.
I'm guessing that you could change the ignition switch so power is supplied to the HEI during cranking.
vicrod
Old 07-24-2012, 04:01 PM
Thanks for the reply. No computer, just old school. Holley 650 Vortex heads, comp cam
Old 07-24-2012, 06:50 PM
LATECH's Avatar
Last journal entry: New Gas Tank
If the starter has a terminal marked with an "I" then hook that to the HEI along with the existing power wire. The "I" terminal is hot when cranking the engine.
Fact is stranger than Fiction
Old 08-06-2012, 02:42 AM
GM/Jeep
Adding the wire to the "I" terminal worked like a charm.
Thank you
jeep wrangler after market air veronica1970 Introduce Yourself 2 06-26-2009 12:35 AM
Five Way harness for Jeep Wrangler offroadn1 Interior 2 03-25-2006 07:20 AM
1988 Jeep Wrangler Jay Steele Engine 6 11-18-2005 09:12 AM
Jeep Wrangler exhaust manifold needs preheating prior to fitment club327 Engine 21 07-25-2004 11:42 AM
