jegs 3000 stall - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2004, 10:23 AM
jegs 3000 stall
i was looking into buying a stall from jegs they make a 2700-3000 rpm stall and i was wondering is this the kind of stall that only stalls when you punch it or is it the kind that is going to stall all the time? thanx
Old 03-01-2004, 01:57 PM
Thom Laybourne's Avatar
Stall
Unfortunately stall is stall. If you push down on the gas a little slower (NOT PUNCH IT) the engaging speed will be a little lower and the take-off will not be as sudden. On a light car with small tires, it will spin them. On a heavier car with small tires it will spin them a little less. With a heavy car and bigger tires, you will have a stronger take-off and very little tire spin. Hope this helps you to understand stall.
hr41pearl
