Jegs 350t trans..... No good!!!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2006, 02:46 AM
tiresmoke55's Avatar
PO-BOYS-TOYS!!
Last journal entry: My new 55 chevy pretty sharp
Hey everyone
I just wanted to tell you guys i went to Jegs over the weekend and spent over $1100 bucks,, I bought A Jegs brand 350t trans and also with that i got a new trans cooler with a fan and all the nice AN fittings w/ braided hose just because i wanted to do everything right u know...
Ok for the price of a Jegs brand trans i really shouldn't be upset, it is only $629+tax But here is the thing there trans are supposed to shift hard and firm for any car with around 400-450hp NOT!!!!! I just got done putting that thing in my car and i dont think it is going to be worth a crap!!! The trans i took out of there had at-least 100,000 miles on it and i think it shifts harder than the new Jegs 350t??
I just wanted a harder shift so i called jegs and was talking to a few of the guys that worked there and they said there trans was really built by B&M but was $200 cheaper and shifted just as hard, so i figured it was a good deal since shops wanted $500 just to rebuild mine u know...... well i guess the guys at jegs lied lol
Has anyone else bought a jegs trans and had any good or bad luck???????
Old 08-10-2006, 09:26 PM
DHMag's Avatar
what type of fluid did you use in it ? B&M recommends B&M Trick Shift or Type F for any trans with a B&M shift kit in it.
if you used Dexron III, thats why youre not feeling the punch.
Old 08-10-2006, 09:38 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
[QUOTE=DHMag]what type of fluid did you use in it ? B&M recommends B&M Trick Shift or Type F for any trans with a B&M shift kit in it.
dittos! Trick Shift is happening
Old 08-10-2006, 10:23 PM
jakeshoe's Avatar
Calibrating shifts is not done with fluid...
Why use an inferior fluid?
Use Dexron and install a valve body kit.
Old 08-10-2006, 11:15 PM
PO-BOYS-TOYS!!
I did use the b&m trans fluid, IM going to give it a few days and at least 20 miles and if it don't get better i guess ill take it out u know....will see what happens...
Old 08-10-2006, 11:59 PM
MR.BUICK's Avatar
Automotive Enthusiast!
Sometimes it takes a while for a trans. to really "break-in". Take it easy for a while and put some miles on it, then start giving it some W.O.T. runs and see how hard and firm the shifts are. I have heard lots of good feedback from customers of B&M transmissions, so they do know their stuff most of the time, I suppose you could pick up a bad apple from them though once in awhile. It has happened many a times before and I am sure it will happen again!
-Cody
Old 08-11-2006, 06:10 AM
Will I ever get it done?
Last journal entry: Hood
Tells us about the converter.
Old 08-11-2006, 08:48 AM
My understanding from books on rebuilding TH350's and from people that rebuilt these was that Type F has a different friction modifier and will make the shifts harsher as it doesn't slip as much. Definately not the same as messing with the valve body, but it will create a difference.
Old 08-11-2006, 11:42 AM
PO-BOYS-TOYS!!
My car has a 3 month old B&M 3500 stall in it that is working great..
Old 08-11-2006, 04:21 PM
Was it the converter in the 100K unit you took out? If not, what did the 100K unit have for a converter?
Old 08-11-2006, 04:53 PM
jakeshoe's Avatar
Type F will make a slightly firmer shift, it has NO friction modifiers according to my literature.
It has a significantly lower heat resistance than Dexron.
IMO not worth messing with, it is also getting harder to find.
I would buy a valve body kit and install that and be done with it.
Old 08-11-2006, 06:52 PM
PO-BOYS-TOYS!!
my old converter was the old style vega converter, it stalled around 2300 to 2600 rpm....i bought a new stall for the jegs trans,,,,
Old 08-11-2006, 07:48 PM
shift
Try to change the shift by adjusting the mod. screw.it will shift harder .
Old 08-11-2006, 09:10 PM
72NOVA454
I would call Jegs and/or B&M and ask them if the trans you bought has their shift kit installed in it. If yes, then you may have a bad unit. If no, I would ask "why not"?
I have a Turbo 350 in my car - a very old one with over 100,000 miles on it and a stock torque converter with over 100,000 miles on it. the trans shifted very softly when I got it. After installing one of the B&M shift improver kits in there, it now shifts very quickly, and firm. It even screeches the tires when shifting from 1st to 2nd. I am running the type "F" fluid, not the B&M trick shift fluid. It took approximately a total of 3-4 hours to complete the (very messy) job and about $50 for the kit. Well worth it.
Like I said, ask Jegs and B&M if the trans you bought has the shift improved kit installed in there.
Old 08-11-2006, 10:53 PM
PO-BOYS-TOYS!!
Hey guys,,,I just got done adjusting the mod and it seems to of help it a little but to be honest for a $700 trans i would think it would shift little harder then what it is doing.... its not slipping or nothing but just not hard at all,,, of course having a big stall will make a trans feel like its not shifting really hard but firm u know... I have only had 1 trans that chirped the tires when having a big stall in it, but all of the trans i have had w/shift kits and big stall's shifted hard enough to feel/jerk you a little bit BUT this jegs trans just shifts firm, really cant feel it shift? like i said before ill give it a week and if its not going to get better ill take it back ,,,,,, And yes it does have a B&M kit in it
Car-toons I mean tunes! kringold Hotrodders' Lounge 107 10-20-2006 08:10 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
C4 trans ident? ptsherman Transmission - Rearend 4 12-29-2004 07:27 PM
stuck drain plug on manual trans steffan_miller Transmission - Rearend 5 07-01-2004 10:15 AM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 01:23 PM
