Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Jerico Transmission question...
Old 04-09-2013, 09:28 AM
Dajerseyrat Dajerseyrat is offline
Originally Posted by lmsport View Post
A super light clutch/flywheel and a 3.08 gear is not going to be effortless to drive the street no matter the gears in the trans.
DO you think swapping out the clutch and flywheel would be a solution to make it more streetable? If so what would you reccomend for it? Im leaning towards replacing the whole tranny and flywheel set up but if I could get away with just the flywheel and clutch I would keep the Jerico if it was the "least" bit streetable..
