Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Jerico Transmission question...
Old 04-10-2013, 09:41 AM
S10xGN's Avatar
S10xGN S10xGN is offline
Gotta love a turbo!
Originally Posted by lmsport View Post
The Jericos I have are stamped with the gear ratios, on the topside of the main case at the bellhousing end.
Hmm, I've got a DR4 box and there is nothing stamped there on it. Mine box has a 3.08 1st gear to be paired with a 3.25 rear axle, Spec stage III clutch, and an aluminum flywheel. This will all go in a lightweight, high torque street combination. In your case, I can "feel" several potential problem areas. Car weight (?), clutch/flywheel (?), gearing (?) and lack of low-end torque.
Russ
