Jerico Transmission question... - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 06-18-2013, 08:33 PM
Off topic but how do you tell when you successfully have bleed your hydraulic throwout bearing?
  #32 (permalink)
Old 06-18-2013, 09:52 PM
vinniekq2's Avatar
put a hose on the nipple and bleed into a jar.Keep the end of the hose submerged in the fluid..When nothing but fluid goes into the jar with zero bubbles,you are done
  #33 (permalink)
Old 06-19-2013, 05:16 PM
Yeah i get a steady flow of fluid but bubbles in between, I cant see how there is THAT much air in the system..I hade to top off the reservoir 2 times already. Ill keep at it, but Im thinking air is getting back in when I remove the hose from the nipple to lock the bleeder valve.
  #34 (permalink)
Old 06-19-2013, 09:46 PM
vinniekq2's Avatar
do not remove the hose from the jar,keep it submerged,,or;
keep your finger over the nipple with light pressure.When the down stroke of the clutch is done,the pressure will push the fluid past your finger.When the clutch is released the finger will seal the nipple preventing air coming back in
  #35 (permalink)
Old 06-21-2013, 11:31 PM
I was using a vacuum pump..I wasnt pressing the clutch.
  #36 (permalink)
Old 06-22-2013, 01:28 AM
vinniekq2's Avatar
get a foot on the clutch pedal and you can use more pressure.open the valve only slightly and watch it come out fast and clear
  #37 (permalink)
Old 07-11-2013, 08:29 PM
Anyone ever drive a Jerico Transmission? Im just curious if they are supposed to be noisy as hell...Loud noticeable "clunks" as it goes into gear when cruising and a PITA to downshift... Im guessing it needs to be rev matched.. When I did go WOT and do a 3 gear hit, it does feel like butter..It likes to be driven HARD I assume..
  #38 (permalink)
Old 07-11-2013, 08:38 PM
vinniekq2's Avatar
RR transmissions are very noisey.They shift great when racing.Its not great on the street
  #39 (permalink)
Old 07-11-2013, 09:05 PM
Thats what I figured. i can get it to make almost zero clunk if I let the rpms drop between shifts. But i can tell you when you get on it, it almost wants to shift itself.
  #40 (permalink)
Old 07-12-2013, 09:15 AM
S10xGN's Avatar
Gotta love a turbo!
There are quite a few You-tube vids on shifting dog box trannies, they all seem to shift fine. I'm sure there'll be an "adjustment period" where you have to get used to it...
Russ
  #41 (permalink)
Old 07-12-2013, 11:04 AM
Russ
Yes I agree. I was just concerned that the clunk when going into gears was not the norm. After listening to the videos, I can hear it in all of them.
  #42 (permalink)
Old 07-12-2013, 12:08 PM
Please know that after awhile you will have to disassemble your gearbox, and clean up the dog rings with a file to remove the burr that will develop. Eventually you'll have to replace the faceplate/ dogrings all together.
  #43 (permalink)
Old 07-13-2013, 01:42 AM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
I'm surprised nobody said this yet, but the transmission has no synchronizers so it's going to be a bi*ch to drive round like a normal car. All the clunking and banging is normal. At your power level a T6060 in stock form would be a great swap.
  #44 (permalink)
Old 07-13-2013, 07:39 AM
Actually mine has the "road race synchros", allegedly.
  #45 (permalink)
Old 07-13-2013, 08:11 AM
S10xGN's Avatar
Gotta love a turbo!
There are no "synchros" in these boxes. The RR sliders are back cut on both edges so you can decelerate and not kick out of gear. The standard sliders are only cut on the upshift side and thus will not hold a load while decelerating. As Nate said, occasional dressing/replacement will be required so these are prolly not a good choice for a daily driver...
Russ
doug nash vs jerico jansen Transmission - Rearend 0 08-13-2007 01:43 PM
Transmission Question mikedag Transmission - Rearend 5 02-08-2007 11:16 PM
jerico transmission guru,s boss56man Transmission - Rearend 0 10-15-2005 07:40 AM
Transmission question and rear end question demitristewart Transmission - Rearend 1 09-14-2005 07:38 AM
Jerico DR4 rfb92345 Transmission - Rearend 0 05-23-2004 09:55 PM
