Jerico Transmission question... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2013, 08:09 PM
I have a 4 speed Jerico tranny in my car, it was in there when I got it so I dont know which model but Im assuming it is set up for road racing. The problem is, I can NOT drive the damn car..I stalled out like 8 times just cruising around the block..
Are there any tips to drive this thing?? Im thinking of dumping it and going with a 5 speed a little more street friendly..Anyone have a tranny and clutch recommendation? Im putting it behind a ********* 389 Stroker..About 600hp.
Also if i decide to sell the Jerico, what should I ask for it?
Old 04-09-2013, 01:36 AM
What rear end gear is in the car? You also are going to need to know what the gear ratios are in the tranny, that is going to be the determining factor on what its worth. If it has some funky road race gear spread in it, its going to narrow the list of how many people would want it or be able to use it in other applications.
Old 04-09-2013, 09:09 AM
S10xGN's Avatar
Gotta love a turbo!
Can't see how it would behave that much differently than a regular manual even if it was a dog box. The roadrace sliders allow you to downshift and stay in gear whereas the drag sliders will tend to freewheel when coasting. Post up the rear gear and box spreads as posted above...
Russ
Old 04-09-2013, 09:40 AM
Describe what kind of clutch/flywheel is in the car.
Old 04-09-2013, 10:00 AM
The rear in the car is a 308. The tranny I would have no clue What tranny would be a good street tranny that can handle some power, but is actually drivable??
Old 04-09-2013, 10:03 AM
The Jericos I have are stamped with the gear ratios, on the topside of the main case at the bellhousing end.
Old 04-09-2013, 10:05 AM
Not sure on the brand but is sounds like a multi disc the way it chatters when the clutch is released at idle. And the flywheel feels super lightweight, cause it revs like a damn motorcycle. Im assuming a heavier flywheel and clutch combo would be easier to drive on the street??
Old 04-09-2013, 10:06 AM
Top side as in the side I would not be able to see while it is installed in the car? so much for that plan...lol
Old 04-09-2013, 10:14 AM
A super light clutch/flywheel and a 3.08 gear is not going to be effortless to drive the street no matter the gears in the trans.
Old 04-09-2013, 10:28 AM
DO you think swapping out the clutch and flywheel would be a solution to make it more streetable? If so what would you reccomend for it? Im leaning towards replacing the whole tranny and flywheel set up but if I could get away with just the flywheel and clutch I would keep the Jerico if it was the "least" bit streetable..
Old 04-09-2013, 10:36 AM
you need a street clutch and a 2.88 T-10 or a 2.98 Muncie-style 4spd If you want to drive this on the street. If that is a road race jerico, the 1st gear is only a pit gear anyway, all your racing is done in 2,3,4. With that axle ratio they're probably in the 150mph range on longer courses in this car.
We support the SCCA A-Sedan series with a spec gearbox. There are Jerico's, TKO's ST-10s, our Muncie-esque 4spd and a couple guys running T-5s.
For racing you'll see guys with 3.08s, 3.23s rears and 2.56 or 2.20 1st gears in the 4speeds . But, its not street friendly for most people.
If this is a street application; either go to a 2.88 T10, 2.98 'Muncie' or a 5spd like a TKO and never use the overdrive since you have 3.08s.
The other option is to jack the axle ratio up to suit the gearbox better. Probably something like a 3.73:1.
Start at the beginning; find out which ratio Jerico you inherited and then we can advise on a clutch/trans or axle combo to suit your budget and needs
Old 04-09-2013, 10:46 AM
Alrighty then..Any illustrations to where the tranny is stamped exactly??
Old 04-10-2013, 07:32 AM
vinniekq2's Avatar
why not trade your complete race car for a complete street car that suits you?start taking out matching race pieces and adding street pieces the car will less good at what it does all for a cost that wont get recooped.
Old 04-10-2013, 10:41 AM
S10xGN's Avatar
Gotta love a turbo!
Hmm, I've got a DR4 box and there is nothing stamped there on it. Mine box has a 3.08 1st gear to be paired with a 3.25 rear axle, Spec stage III clutch, and an aluminum flywheel. This will all go in a lightweight, high torque street combination. In your case, I can "feel" several potential problem areas. Car weight (?), clutch/flywheel (?), gearing (?) and lack of low-end torque.
Russ
Old 04-10-2013, 11:37 AM
Russ
I have a two, three and a couple four speeds, all with the ratios stamped on the case. I think all mine came from Hightower, so maybe he stamps them and Jerico does not. Sorry for the confusion.
doug nash vs jerico jansen Transmission - Rearend 0 08-13-2007 02:43 PM
Transmission Question mikedag Transmission - Rearend 5 02-09-2007 12:16 AM
jerico transmission guru,s boss56man Transmission - Rearend 0 10-15-2005 08:40 AM
Transmission question and rear end question demitristewart Transmission - Rearend 1 09-14-2005 08:38 AM
Jerico DR4 rfb92345 Transmission - Rearend 0 05-23-2004 10:55 PM
