Jet 4l80e Tranny Chip Concern - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2006, 05:51 AM
ALASKAN's Avatar
HI FOLKS
A FEW YEARS AGO WHEN I RAN AROUND THE COUNTRY-WITH MY RIG THAT SPORTS A 4L80E JET TRANSMISSION-I HAD NO PROBLEMS GOING OVER MOUNTAIN PASSES AT 65MPH AND THE TRUCK TOWING A TRAILER SEEMED LIKE IT WAS NOT EVEN WORKING HARD AT THOSE SPEEDS GOING UP HILLS.....WE RAN IT 5K HARD MILES LIKE THAT AND IT DID'T EVEN BREAK A SWEAT;;;NOT THE TRANNY OR THE 383 STROKER FUEL INJECTED STEALTH RAM.....PUSHING ABOUT 300 PONIES AT THE REAR WHEELS....
THEN WE STOPPED INTO A SHOP- A VERY GREAT HI TEC WORLD FAMOUS SHOP-I WILL NOT MENTION THE NAME--AND HAD THE TRUCK DYNOED ON A MUSTAD DYNO AND SURE ENOUGH IS WAS PUSHING 295 HP AT THE REAR WHEELS AN ABOUT 450 AT THE ENGINE.....
THEN THE HEAD GUY THEIR DID SOMETHING I REGRET STILL TODAY---HE CHANGED THE CHIP IN THE JET 4L80E HE SAID TO GET MORE POWER AND THAT WAS THE LAST OF THE GOING OVER THE HILLS AND MOUNTAINS AT 60-70 MPH.....
NOW WE HAVE TO GET INTO THE SLOW LANE-EVEN ON SMALLER PASSES AND IF WE MAKE IT OVER THE TOP AT 50MPH WERE DOING GOOD BUT THE ENGINE IS WORKING HARD--TOO HARD....THIS IS NOT MY IMAGINATION IT IS WHAT HAPPENED ...SO CAN ANYONE TELL ME WHAT HE DID AND HOW TO GO BACK TO THE WAY IT WAS WHEN I EVEN GOT BETTER GAS MILEAGE.....THE ENTIRE RIG ONLY HAS 30K MILES ON IT SO ITS NOT OLD AND TIRED....
AGAIN AM I NUTS OR DID HE MESS SOMETHING UP WHEN HE CHANGED THE CHIP IN THE 4L80E JET TRANNY.....PLEASE ANY THOUGHS ON THIS AND HOW TO GO BACK WOULD BE WELCOME VERY MUCH INDEED....
THANKS IN ADAVANCED FOR YOU IDEAS
ALASKAN
JOHN
Old 04-10-2006, 01:13 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Go back to that Hi Tec World Famous shop and get him to replace your original chip.
Old 04-11-2006, 10:00 AM
ALASKAN's Avatar
Can't Get There.
Hi Hb
I Surley Would If I Could-but Like Most Hi Tec Fancy Shops They Went Out Of Buiness And The Owner-guy Who Changed The Chip-is Long Gone...so With That Said And Thanks,,anyone Got Any Avenue's Were To Start. Does Anyone Know About Jets Trans Chip Change Box,,,were You Can Dial In Anytype Chip You Need And Should This Fix My Problem...
Thanks
John
Old 04-11-2006, 08:02 PM
Crosley's Avatar
Wiki Edits: 1659
Originally Posted by ALASKAN
Hi Hb
Thanks
John
Since Jet performance is still in business, I'd start there with questions.
http://www.jetchip.com/
Need some tranny help. 4l80e Bruce Wang Transmission - Rearend 3 09-19-2005 03:19 PM
Tranny update/Torque converter question RObs71Nova Transmission - Rearend 5 12-16-2004 09:37 AM
Pulling motor/ tranny 66 C10 66thom Engine 6 10-27-2003 09:46 AM
Tranny fluid heating up engine??? black66 Engine 1 07-13-2003 09:18 PM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 04:53 PM
