Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Jet Change Effected Idle
Old 05-24-2010, 09:16 AM
kpcrossfire6's Avatar
kpcrossfire6 kpcrossfire6 is offline
Pull out your idle mixture screws, take an air hose and hold it into the hole and blow air in their for a couple seconds on both sides, clean the ends of the mixture screws etc. then reset the screws again. also it doesnt hurt to take some carb. cleaner and put a little bit in the fuel bowls as well.
good luck,
