John C - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2006, 01:10 PM
John C
What is the best rear end to use to up date a 48 plymouth and best gear ratio for overdrive? John
Old 01-06-2006, 01:41 PM
Best ??
Well, lots of different opinions on that. I prefer the 9 inch Ford. Easy to find, easy to work on and inexpensive in most parts of the country. A 71 to 73 Mustang has the same general width rear as your car and the Mustang rear works well. It has a the very common 5 on 4.5 inch wheel pattern ( common to Ford and Mopar ) ....
With the drop out center sections of the 9 inch Ford...rear gear ratios changes are easy and there are many choices. I like a 3.70 with a OD.
Deuce......
Old 01-06-2006, 07:10 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
i have a 350hp/350, 700r4 and 3.08 in my vette but in reality i wish i had something in the 3.30- 3.50 range. go to WWW.700r4.com and use their RPM calculator and play around with different ratios....the ideal ratio would have no MPH in 4th that creates a bogging situation with your engine (such as 40mph/800 rpm)
John Deere Blitz Black?? motoedge Body - Exterior 425 04-17-2007 06:25 PM
Color from John Deere? SMF Speed&Custom Body - Exterior 0 06-25-2005 11:04 PM
The truth about John Kerry z3pr Hotrodders' Lounge 4 09-15-2004 07:51 AM
John Force Cruise photos xl1ken Hotrodders' Lounge 2 08-28-2003 03:59 PM
