Hotrodders Bulletin Board
#316
I think what you will have to do is sand the truck to ruffn it up and use JD Primer and then The paint.
Somone please correct me if i am wrong though. |
#317
I just wanted to post this because this is one thing that has not been covered in this post. I emailed Shawn Mahady about the rattle can primer, and he emailed me back and said it should be fine to apply JDBB over the primer but spray a small area to test it out first!
Jason 77 f100 |
#318
There's something about using the JD buff primer somewhere in this huge thread, but I don't recall if it specifically addressed the rattlecan version. Regardless, I bought a can of the buff primer when I picked up my BB rattlecans and it worked fine. Overall my paint turned out mediocre but I didn't have any problems with the buff primer. Good Luck!
#319
Thanks,
yea, the Buff primer is mentioned alot but I emailed Shawn asking because I used cheap Wally World rattle can primer, not the JD Buff in a rattle can. I have a compressor and gun now so I am not going to use rattle can BB. I was trying to make sure I didn't need to sand all the cheap rattle can stuff I put on off and then apply the JD Buff primer then the Blitz Black. |
#320
I want to paint my 66 Dart GT JDBB, but it is not available in CA. They do carry #TY25825. I guess it is the low VOC version, which is about $70 a gallon and the hardener is about $65. What is up with that? I think I might just drive to nevada to get some. Just a pain in the *** if you ask me. Any suggestions??
#321
Okay I finally got my paint after having to go through two dealers and waiting 3 weeks! I was reading the instructions on the back of the can and after reading everything in this thread that says 8:1 ratio the can has 10:1 on it!! What should I do follow the directions on the can or go with the 8:1?? I can't wait to have my truck all one color again. I hasn't been all one color in about 8 years! Thanks for the help!
Jason |
#322
I heard you cant paint automotive paint over rattle cans later if you want to change the color. I heard the type of paint in rattle cans makes regular automotive paint wrinkle. Is the paint in the rattle can the same as the paint they sell buy the gallon.
#323
There is a post in this thread which states the Blitz Black in a can is the same as the real deal. If you think about it, the prep you would do for a real paint job will probably do away with your rattlecan paint - you'll sand right through it. Hopefully some experts will weigh in.
#324
Depends on the paint in the rattle can.....and what your original paint is....If it's a cheap enamal, which many are, it will wrinkle. If it's a laquer based, or other strong solvent based, it will not. If you are spraying laquer over a cheap enamal, it may wrinkle that paint. |
#325
hey im interested in getting a gallon of this paint to paint my 70 lemans how does this paint hold up for a car that will be used everyday and where can i get a gallon i called one of there stores and they said they didnt make gallons only cans any help would be great
#326
I don't know how it holds up, but from reading all of these posts it should do very well. I got my gallon in last Friday. I had to go through two different dealers though. The first one here in town said he could order it for me then almost 3 weeks later said he couldn't get it but he put me in touch with another dealer in a town 30 miles away. I called the other dealer and luckily he was coming right by where I work to deliver a tractor so he dropped the paint off at work for me.http://dealerlocator.deere.com/serv...te=&postalCode=
here is a link that is on page two in post #28 that will pull up all the dealers in your area. I hope this helps. Jason |
#327
yeah i called 2 places in my area and they both said they cant get gallons maybe i will try some others
#328
paint
I have already posted my car in this section. But here are a few shots again of my JD paint. I did not use any flatening agent. I mixed the JD 8:1 and this is what I came out with:
#329
that is just simply awesome. that is not blitz black though is it? a medium gloss or what? you also waxed it to right? |
#330
Paint
The paint is JD Blitz Black. No flatening agent. No wax.
I just took this pictures of the remaining pints in my garage.... ![]() I sprayed one tack coat and then one really wet coat within 10 minutes of each other. It took 2 hours in the oven and another 3 hours out side for the paint to dry to the touch.... Here is a very short video of the car at night....... JD Paint I am not a professional painter by any means but I am very happy with the results for my first paint job ever. My car still needs some body work and the trim holes welded up. So I will be painting the car a second time at the end of summer.... I painted this in the summer of 2003. Dave Last edited by black66 : 04-09-2006 at 01:20 AM. |
Back to top |
| This discussion has been added to the Body - Exterior Discussions category of the Hotrodders Knowledge Base. |
