john r chase - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2006, 02:52 PM
john r chase
I am putting disc brakes on the front end of a 48 Plymouth convertible. What should I use for a dual master cylinder that will fit under the floor as the original did? John
Old 01-27-2006, 06:08 PM
Silverfox031's Avatar
StreetRods & Customs Forever
Last journal entry: 37 Ford customized WildRod "Leilani"
Brakes
John, check with this company www.mpbrakes.com they should be able to provide all answers and equipment to solve your problem
Old 01-27-2006, 08:50 PM
johnrchase
Thank you I wil do that. John
Old 01-27-2006, 09:10 PM
johnrchase
I tried the web page given and it doesn't go through. Do you have a phone # ? Thanks John
Old 01-28-2006, 12:47 AM
John,
What disk brake setup are you using?
Old 01-28-2006, 01:55 AM
Hi . Mopar DUDE!! I would use the willwood mopar master cylinder .I noticed the Bigger bore DIA. the better on stopping.Or get one from the bone yard.. The chevy and ford guy's use them too .. HA,HA,HA,! And they say mopars are WHAT?!!! Any how I am using one in my 67 valiant and I really like it .. Try one out .. It's only a mopar product anyway... Take care ! If you like mopar ! Your O.K.
You might have to make a few brackets to mount it under the floor ,but that is really easy .. Think of it as a drag car set up...
Old 02-01-2006, 10:39 AM
johnrchase
Originally Posted by polkat
John,
Sorry it took so long to get back to you, we are flooded because of record rain fall and wicked storms. The Plymouth is o.k. The brakes are from Engineered Components. www.ecihotrodbrakes.com Thanks any help will be appreciated. John
Old 02-01-2006, 10:47 AM
johnrchase
Thanks for the info, do you have a part# or year of cylinder?
Old 02-01-2006, 11:31 AM
302 Z28's Avatar
The most common master cylinder used by street rodders is not a Mopar unit, it is a 67 to 72 Corvette 427cid 435hp manual 4 wheel disk brake master cylinder. They are cheap, either new or rebuilt and readily availiable. Stay away from the boneyards on this piece, it just isn't worth it. The Wilwood unit is a superb unit $$$$$$, but what are you going to do when it starts to leak on you in the middle of a rod run, or a cross country? And they will eventually leak in that mounting position under the floor near exhaust. The Vette master can be replaced at just about any auto parts store nation wide. I would however stay away from rebuilt units, go with new only. It will cost you about $60.
Vince
Old 02-01-2006, 12:39 PM
Vince
SUPER advice........
I am all for saving money, and I understand " limited budget.....ALL to WELL, But brakes are not the place to cut corner's or try to save money $$$. SAFETY FIRST....
Old 02-01-2006, 03:47 PM
johnrchase
Vince
Thanks, I was not looking for anything cheap just didn't know what to use. The Vette one sounds good to me. John
Color from John Deere? SMF Speed&Custom Body - Exterior 0 06-25-2005 11:04 PM
help with John Deere Blitz Black hondadude Body - Exterior 17 11-03-2004 03:29 PM
The truth about John Kerry z3pr Hotrodders' Lounge 4 09-15-2004 07:51 AM
Car chase Mikey_mike Hotrodders' Lounge 6 09-13-2003 10:27 PM
John Force Cruise photos xl1ken Hotrodders' Lounge 2 08-28-2003 03:59 PM
