JOINING BRASS & PLASTIC PIPE THREADS - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2009, 11:23 AM
I have a jet pump that needs a check valve installed on the inlet side. The max water pressure is probably going to be 60 psi or less. The pump has 1" PVC connected to it. I need to cut the PVC about 4' out from the pump and and put the check valve in between two plastic fittings. The plastic fittings are male threaded and the check valve has female threads.
I have done something similar to this before using teflon tape and had a hard time getting a good seal. Would pipe dope work better or do you guys have any other recommendations?
Old 07-28-2009, 12:06 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I have used a pipe dope with teflon in it with a good success...
Sam
Old 07-28-2009, 09:02 PM
4 Jaw Chuck's Avatar
This is what I use;
http://www.rshughes.com/products/079340_80724.html
I haven't found anything better, I do a lot of plastic to stainless NPT fittings for medical eqpt.
Use of Plastic or Brass Fittings in Fuel Line? JohnTN General Rodding Tech 8 11-02-2007 09:57 AM
Plastic pipe for radiator plumbing? CayoRV General Rodding Tech 7 05-31-2007 04:31 AM
air lines CARGUY Garage - Tools 96 11-16-2006 04:11 PM
Garage Safety Kevin45 Garage - Tools 48 11-26-2005 08:49 PM
Airlines Kevin45 Garage - Tools 22 03-04-2004 04:35 AM
