Journal Indexes - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders Site Suggestions and Help
Old 01-23-2009, 02:40 PM
PSST's Avatar
1927 Vette
Journal Indexes
Cboy recently posted an index in his latest journal (Cboy-Two) and asked for some feedback about it. I have been viewing a number of journals and I sent him some comments. Between the two of us we managed to arrive at the idea that using links to the pages could be made to work. Basically it gets around the problem of having to View from Beginning and jump back and forth in the journal to find topics of interest.
I thought I had seen a link previously somewhere in one of the journals so I thought I would give it a try and used Cboy's journal to experiment on. I am not aware of any journal indexes built using the following but if I have missed someone else's previous idea I apologize. There may be better ways of doing this (but that is why I am posting this to find out if there is).
The procedure I used was as follows:
I am assuming that the person with the journal has an index in a another program on their personal computer. Cboy uses Word Perfect and I am going to use Microsoft Wordpad. Any text program will do, as will others.
The basic form of the index is a topic and a page number. I can't get at entry numbers since the journals are built as tables.
Go to your journal (any page) and right click on an entry and select Properties. A box will come up with some information in it. On the line that starts http find the code that says journalid=number. The number is a unique journal id assigned to your journal. Remember this number since you will need it again.
In your journal index create an entry such as (this is the hard part):
[lru=http://www.hotrodders.com/forum/journal.php?action=view&journalid=Your_Number&page =Your_Page&perpage=5&reverse=true]Your_Topic[/lru]
where Your_Number is your journalid number, Your_Topic is the name of the topic you want to create a link to and Your_Page is the page number in your journal to that topic. Make sure you don;t make any error typing.
PLEASE NOTE THAT I HAD TO MISTYPE url AS lru SO THAT THE HOTRODDERS.COM POST SOFTWARE WOULD NOT INTERPRET IT AS A LINK. JUST CHANGE lru BACK TO url AND EVERYTHING SHOULD WORK OK.
Repeat as often as you need to.
To test out your journal index, copy the contents from the text program you are creating it in and past it into a PM to yourself. In that PM you should see your topics and if you click on them you will get to the page that contains the information about that topic. This allows you to check it offline without putting it into your journal until you are ready.
To make it clearer, go to Cboy_Two's journal and you should see his new index. Try it out to see if it is what you need. If you like it I can send you the text file I created to make it. It is easier that starting from scratch.
Hopefully I can get the instructions in a better form if needed, but I wanted to get this out before I forgot how I did it.
Ron
Old 01-23-2009, 03:36 PM
poncho62's Avatar
Wiki Edits: 5
Good idea...So basically you are using a hyper link to create the index. .....Can the journal be added to later, and keep the index in the same location........
Old 01-23-2009, 03:44 PM
PSST's Avatar
1927 Vette
Hyperlinks
ponch62:
More or less correct...
The journal index entry itself is just like any other journal entry except that it contains the links to each of the topic pages of interest. As long as you can edit the journal index entry you can edit/add/remove the links to the topics as needed.
I am planning on using multiple journal indexes when I start my journal. They will be at set locations (every 50 or 100 entries) throughout the journal so that I don't have to wait until the end to start on them...
Old 01-23-2009, 04:16 PM
poncho62's Avatar
Wiki Edits: 5
Cool...Maybe Jon can look into something that will have the index page stay on the 1st page.....and then all additions would come after that.......
Old 01-23-2009, 06:05 PM
cboy's Avatar
Last journal entry: Finished
That would be a help. What I do now is simply delete my Index every time I go into my journal to make new entries. After the index is deleted I make the entries I want and then, just before closing out, I copy the Index from my Word Perfect directory and insert it as my final entry of the session. This is sort of a PITA, but it does allow the index to come up first when you access the journal.
The other thing that would help is if Jon could put the edition helps (the little mountain icon and the blue "earth" icon) onto the journal editing screen. The blue earth icon would make PSST's process a snap. Just copy the referenced page in your journal, hit blue earth, insert the index topic you want, and then just paste in you url that you copied earlier.
What PSST has done is to give us some code which does basically what the blue earth icon does...only it takes a bit longer this way. My feeling is anything we can do to make the journals (particularly all the longer ones) easier to access, follow and read will greatly improve their usability.
Also PSST, did you have to be in "view from beginning" mode when collecting the info from the referenced page in the journal or will your system for creating the link work while you are in the default "view from most recent"?
Always learning...and sharing what I've learned.
Old 01-23-2009, 09:03 PM
PSST's Avatar
1927 Vette
Viewing order
Cboy:
I was using the default viewing order (most recent). All I did was click on a page (other than the last one) and see what the page number was. It was correct so the order must have been correct. I think that is why the &reverse is in the link information??
I just checked your journal by going to it, clicking on the view from beginning, then going to the journal index (now on the last page and in the last entry) and clicking on a link to a topic. It still works...
Ron
Old 01-23-2009, 09:17 PM
cboy's Avatar
Originally Posted by PSST
... It was correct so the order must have been correct.
Good. That makes things pretty straightforward then.
Old 01-27-2009, 09:56 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
I just updated mine. I just grouped by project for now, but at least I have the format so I can expand later.
http://www.hotrodders.com/forum/jour...ournalid=20616
Old 01-27-2009, 10:27 PM
PSST's Avatar
1927 Vette
Arrowhead
I visited your index. Looks like you have the hang of it. The journal looks great.
400 SBC build.. michaelbarry Engine 20 10-11-2008 07:22 AM
327 large and small journal motors 31 Ford Coupe Engine 9 09-08-2008 01:09 PM
Journal "identifiers" cboy Hotrodders Site Suggestions and Help 4 12-10-2007 07:47 PM
Mini Tutorial - Adding an index to your journal cboy Hotrodders Site Suggestions and Help 0 11-06-2007 08:15 PM
new round of Journal testers needed Jon Hotrodders' Lounge 0 03-18-2005 03:27 PM
