Not sure what you mena by low pressure they are for efi they are all high pressure. All the turbo guys use this one when they can find it. Also works god for oil for remote mount kits.
Where is the fuel pump located on a 2003 Ford F250 6.0 diesel Also in the same spot on a few other years as well. |
junkyard gurus, Ineed help
AP72, Most fords with dual tanks have an inline pump located on the fuel rail. I know for a fact the 1995 Ford 150 extended cab have these pumps.
My ski boat uses a low pressure high volume pump to keep a cannister with a fuel filter, and the high pressure fuel pump inside full of gas. This cannister just has a hose that opens back to the gas tank, and fuel just gets dumped back in the tank. Any air that makes it to the cannister also get dumped back in the tank.
this is a picture of the low pressure fuel pump, with the top place removed to clean a screen inside the pump.
the fuel rail pump is not made to suck fuel.. it boost the psi from the fuel the pumps in the tanks sent it.. |
Heres a link to one just the first one to pop up in google. I have used these before with good results but usally buy from napa. SBC CHEVY High Volume Chrome Fuel Pump 283 327 350 400 - KMJ Performance Fyi the other pump i mentioned is good for efi turbo system into the 500+ hp range. I dont think its the one for a carb setup. |
it's for a ford 2.3L that was originally EFI (no fuel pump boss). It's a built engine, but only about 150hp at the wheels (hey its only 4 cylinders) and will probably only do a 100hp shot.
Ford motorsports makes a great roller cam for the n/a 2.3 If your serious I know someone with an after market 2.3 liter head. Not sure if its for sale but I know you cant find them anywhere. Not like this. But also totaly custom. Stock intake and exhuast does not bolt up. WIth the head and the 2500 kit I here they can make almost 300 puppies without the turbo if built right. One thing is for sure that engine will take some abuse. |
Some of the pre turbo 7.3 fords had an inline pump that supplied the mechanical pump. Mine was an 89, not sure what the exact volume was.
I love itbs and bike carbs but your going to have some issues tuning for a low compression low rpm engine. You may need to drill the idle air ports tp make that work. Or under size them a little if they are from a bike. The four barrel manifolds actually work well. You can buy a real good four barrel and a good webber setup. Im sure you seen this site they are the go to ppl for 2.3 unless your trying to 9 k rpm then its ford motorsport beleive it or not. Since they use the 2.3 in a indy style race car ford supported. Sorry for crappy link. http://www.allfordmustangs.com/forum...ng-catalog.pdf |
The compression is at like 9.8:1 so its not too bad- I'm more worried about tuning the carbs with the big cam than anything else. |
Remeber to get the mains right then try to tune the rest. You may not need to touch the needles for the mids, wont know until you got it dailed in. If you change the mains once its dailed in you will need to retune to get smooth transistions. Basic bike jet kit type stuff shimm the needles or replace them. Also be sure you get side drafts and not down drafts. Most newer bikes that had carbs were down draft. R6 and r1 carbs point straight down in the bike so the floats are in different location. Suzuki sv1000 has two very large throttle bodies if you decide to go efi. Four of those should be very nice. Have you figured out a manifold. I used a flat plate of alum and intake manifolds from motor cycles. If you look around you should be able to find manifolds that bolt down with two bolts for each carb. Then just bolt the plate to the head. I know sounds easy right i did need a mill to make this work. |
| 12 bolt id gurus | ganymede | Transmission - Rearend | 4 | 04-25-2012 06:17 PM |
| for edelbrock gurus | RotorHead | Engine | 5 | 10-19-2011 01:17 PM |
| camshaft gurus help? | chevy302builder18 | Engine | 2 | 09-13-2011 04:12 AM |
| Any International Gurus? (IH) | rustycarr | Hotrodders' Lounge | 5 | 06-06-2010 11:01 PM |
| transmission gurus ? | nvrl8 | Transmission - Rearend | 1 | 09-21-2004 04:52 AM |
