Junkyard mods...Twin M90 Supercharger 302 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-10-2011, 11:57 AM
Anything that is made for the Mustang will fit the Cougar, and there is a front clip available.
http://www.mustangandfords.com/techa...uspension.html
  #17 (permalink)
Old 07-10-2011, 05:53 PM
67MercCat's Avatar
Junkyard Dog
awesome! that will dramatically change the potential direction of this project. So the Aston set up seems to be the most logical way to mount the superchargers while effectively intercooling the air flow. They have all those great engineers so I'm sure they know what their doing. Now I'm trying to decipher how they mounted the S/C to handle all that turning thrust. Maybe a rig attached to the head bolts, or maybe a bracket from the intake.
This guy here did a great job on his m90 project http://www.britishv8.org/articles/mg...percharger.htm he made his own intake to mount the S/C right on top
Sswweeettt!
  #18 (permalink)
Old 07-10-2011, 06:32 PM
This is what I'd do..........
Mount the superchargers upside down with the discharge vertical and the drive snouts replaced to shorten the overall length. Fab up some brackets to mount the superchargers on each side of the engine and use the pullies to run each at 5 psi each. Fab up some plenums with the discharge pipes for the outlets of superchargers. Direct flow to front mounted intercooler, with intake on the sides and a top mounted outlet which then goes to the carburetor bonnet.
  #19 (permalink)
Old 07-10-2011, 09:41 PM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
I would probably make a pair of Paxton style mounting brackets that use the bolts on the front of the m90 case to bolt to the heads,and then put a few tubes off the back and bottom to other points on the motor to finish it off
  #20 (permalink)
Old 07-13-2011, 12:49 AM
67MercCat's Avatar
Junkyard Dog
So I've take your advice guys and started drawing up rough templates out of cardboard. I did some drawing in my book first about how I wanted things oriented. Then started cutting out cardboard pieces for a more 3-D image of whats going on.
Here some pics, I want to use the lowROLLERchevy idea about using the front bolts to mount the S/C to the Heads. and the rear inlet can be supported by some header bolts.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG] [IMG][/IMG]
  #21 (permalink)
Old 07-16-2011, 12:30 AM
67MercCat's Avatar
Junkyard Dog
hmm. after some further thinking, mounting the superchargers how lowROLLERChevy suggested might not work. The supercharger oil is contained between the turning gears and snout with NO gasket by the front bolts, so adding a bracket to that might cause leaks because of vibration. I prefer to stay with the original intention of the Eaton designers and use the mounting bolts on the sides of the supercharger housing somehow.
  #22 (permalink)
Old 07-16-2011, 05:43 PM
When you remove the snout, clean the mating surfaces with acetone and a lint-free cloth, then apply a THIN bead (1/16" or so) of loctite 518 (or permatex 51813) to the flange on the charger.
That will keep the oil in, and vibration won't affect it since it cures to a flexible gasket.
And yes, I registered just to say that.
  #23 (permalink)
Old 07-16-2011, 09:01 PM
Wiki Edits: 22
Studding the area and using one set of nuts to hold the case together, and another set to hold the m90 to the bracket will also help.
  #24 (permalink)
Old 07-18-2011, 10:52 AM
67MercCat's Avatar
Junkyard Dog
thats a good idea, I'll take that into consideration in my design. I'm going to the steel mil today to pick up some plates. How thick do you think the plates have to be to support the S/C. Each one is at least 35 pounds and their going to be under high rpm torque.
I'm still dancing around with a few ideas about the mounting orientation though.
  #25 (permalink)
Old 07-18-2011, 10:55 AM
67MercCat's Avatar
Junkyard Dog
haha welcome to the forum! thank you for the info!
  #26 (permalink)
Old 07-18-2011, 12:32 PM
Wiki Edits: 22
I would say 3/16 or 10 gauge (.1875 or .140) Since the mounting plates are attached on the same axis as the rotational force you dont need much, Once you get some sort of a side or rear bracket that bolts to the intake / exhaust bolts it wont go anyplace.
  #27 (permalink)
Old 07-19-2011, 11:46 PM
67MercCat's Avatar
Junkyard Dog
okay I went to M&K Steel Mill and got a hold of some 10 gauge steel plates I'm going to finalize the templates and trace them onto to the steel using an awl.
Since the snout has a sump the allows the blade gears to sit in the oil and kinda offset, I'm going to have to make the bracket work somehow. Maybe a cut it out or on the front side of the snout.
  #28 (permalink)
Old 07-22-2011, 08:00 PM
67MercCat's Avatar
Junkyard Dog
here's another guy who put the juice on the 302...
http://youtu.be/MZ05_qkp5Yc
  #29 (permalink)
Old 07-22-2011, 08:07 PM
Hmmm.......looks familiar. Hehehe
  #30 (permalink)
Old 07-22-2011, 08:49 PM
67MercCat's Avatar
Junkyard Dog
IS THAT U CLEANSPEED!!!!! *%@*ing awesome man! u rule, this is gonna be fun, any vids of it driving?
Tbi from junkyard bigdog7373 Hotrodding Basics 19 02-02-2011 11:30 PM
JunkYard TBI projectjohn Engine 2 04-13-2006 12:57 PM
junkyard dog ! oldsgeek Engine 7 09-07-2004 12:05 PM
Junkyard Dog NAIRB Engine 14 01-05-2004 01:12 AM
twin-turbo or supercharger? Fireball Engine 5 03-07-2003 06:33 PM
