Junkyard/Salvage Yard Parts Paint Marking removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2006, 12:25 PM
Cebby's Avatar
www.TOOLandFAB.com
Last journal entry: 1UZFE (Lexus V8) swap into 1993 4Runner
Not sure if this is the right section or not. I've picked up a few pieces for my build from various salvage yards and they all use some sort of paint to tag their items (I guess so they don't get other yards parts returned to them?).
Anyway - how should I go about removing this paint without damaging the part. Worst case, I can completely strip it with aircraft stripper and repaint the base piece, but I'd prefer to avoid this if possible (these are primarily external engine parts).
Not sure if this is the right section for this question. I did a search, but it didn't return anything pertinent - I might be using the wrong terms though... Mods feel free to move...
Old 08-01-2006, 01:04 PM
Last journal entry: Long time no journal entry, pulled hood tonight.
bead blasting maybe?
Old 08-01-2006, 01:07 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Is it just like a paint stick paint? If so I have had good results with brake clean and a shop rag.
Steve
Old 08-01-2006, 03:23 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I used a bit of mineral spirits to clean off some of that stuff. Worked great on a plastic fan shroud, but wasn't worth a crap on a set of mirrors for my '79 Monte. Different base material on the part, and length of time it was on probably had a lot to do with it.
In a while, Chet.
Old 08-01-2006, 06:14 PM
Cebby's Avatar
www.TOOLandFAB.com
Here's what I'm dealing with - I have a few parts like this I need to get this stuff off of:
Old 08-01-2006, 07:45 PM
Last wiki edit: Window removal and installation Last photo:
Wiki Edits: 11
I 've had success with lacquer thinner. Sometimes I've had to "soak" the marks a bit with a rag soaked with thinner. That and a wire brush has worked on the toughest stuff for me.
Old 08-05-2006, 07:50 PM
Maybe acetone?
Old 08-05-2006, 10:34 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Lacquer thinner on a Q tip. If you are very careful and only use a little at a time you should be able to get it off. Just dab in on the tag and wipe it off. You will have to experiment with each tag but you will get good after a short while. When you get most of it off you can try using rubbing compound and then polishing compound for the last little bit. Take a few of your old parts to the places where you bought your parts from and have them tag them and then practice on those pieces. If you screw up you can always repaint the whole thing. Good luck.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 08-06-2006, 12:27 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Dremel tool with the little wire brushes can help as well..
Sam
Old 08-06-2006, 09:30 PM
junkyardjeff's Avatar
I would make sure its good before you remove the markings as they might not want to make it right if its removed,I usually do not remove the markings if the parts are going on my daily drivers due to my laziness. Jeff
Old 08-07-2006, 12:45 PM
daveh's Avatar
WD-40 will get it off. Put some on let it sit and come back later. I have good success almost 95% of the time.
Dave
Old 08-10-2006, 02:32 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
If you can get some, and you have no rubber / Plastic parts...
Methyl ~ Ethyl ~ Keytone (MEK) will remove ANYTHING..
Be careful with it, wear gloves, Goggles and a respirator..that Stuff can kill you..now and later.
Do it outside with good ventilation, and Do not spill it on your driveway..It will MELT asphalt.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-11-2006, 11:24 AM
Cebby's Avatar
www.TOOLandFAB.com
Originally Posted by JAKE 68 GMC
Maybe acetone?
Finally got around to trying some things. First thing I grabbed was Acetone. Took the paint markings right off and left the factory finish.
Thanks for all the replies!!
I have some other items that need to have this marking paint removed, so I'll try the other things suggested here and post up the results.
Old 08-23-2006, 11:13 AM
Normally if I tell them I won't be returning it they wont mark it. They mark them in case you need to return/exchange it.
Old 08-23-2006, 12:52 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Brake fluid is another one. The paint lifts, wrinkles, and wipes off.
You have to let it soak for a while though ... overnight?
Removal of paint over spray??? juveteach Body - Exterior 14 03-18-2010 08:48 PM
engine paint removal Grey80Ghost Body - Exterior 3 08-06-2003 04:10 PM
1st painting nova33 Body - Exterior 19 06-16-2003 10:05 AM
Need advice on paint for detail parts Randy Owens Body - Exterior 4 02-14-2003 04:23 AM
electrolisis paint removal stubbys 55 Body - Exterior 3 12-27-2002 04:07 AM
