JunkYard TBI - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2006, 01:17 PM
JunkYard TBI
Ok I have some questions about TBI. What I would like to know is what specifically would be needed for a swap. From what I have found out is the intake, heads are different for a small block Chevy. But that depends on the year of the motor. So I would need those. A Computer , wiring harness. What I don't know is about sensors like knock sensors, water temp sensor, and map sensor. Is there any other sensors that I would need to make the swap?
I would like to know anything else because it's one of those all you can carry sale so I would like to know about anything and everything.
Right now all I have on my list is
-heads
-intake
-throttle body
-all wiring that I can get
- computer
Also what type of cfm do these things flow? I know they are different for the different size motor.
Any help with this would be appreciated
John
Old 04-13-2006, 01:40 PM
Don't piece meal it. You will always doubt something. Find a motor/vehicle that has all the parts and take them. It will be cheaper and you avoid the little things nobody knows about.
For example there are 2 different distributor housings both look the same but they are different and should be kept with the intake manifold they were made for.
You may be making this way more difficult than it is worth. Really get all the parts from one vehicle. They are not that hard or expensive to find.
IMHO.
For all the parts you need look at aftermarket kits and see what they include some tell you the part numbers. Better yet find the schematics they are on the web and check them out. You will be resorting to the schematics often.
Are you going to run a 700r4. Find a stock harness if so.
Good luck!
Old 04-13-2006, 01:57 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Originally Posted by evltwin
Don't piece meal it. You will always doubt something. Find a motor/vehicle that has all the parts and take them. It will be cheaper and you avoid the little things nobody knows about. Really get all the parts from one vehicle. They are not that hard or expensive to find.
He hit the nail on the head. In fact get the whole vehicle if you can, you'd be amazed what you'll be able to use off it. You'll need a TBI compatible electric fuel pump, regulator and a return line to the fuel tank as well. You don't need the TBI heads and you can use a 4 Bbl intake manifold with a Throttle Body to 4 Bbl. adapter GM even used an adpter on the early 454 TBI trucks but using the factory TBI manifold or equivalent aftermarket piece makes hooking everything up a lot easier.
5L TBI to 5.7 TBI swap headscratch Gearhead forever Engine 2 06-07-2005 12:24 PM
Tbi Mods NAIRB Engine 8 05-03-2005 07:50 AM
TBI "High Idle Problem": conoverbandit Engine 9 02-08-2004 12:49 PM
TBI Questions on a 93' Chevy FS 350 IWANTMOREHP Engine 1 01-04-2004 02:42 PM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 08:01 PM
