Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Just bought a 1972 Skylark that needs tuning?
Old 11-13-2012, 08:35 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
under the hood the factory has posted the tune up specs.Basically do that. when you have a few extra dollars,consider changing the points to a none points ignition.Either put a kit in the factory distributor or adapt a GM HEI distributor(high energy ignition) to rebuild that 2 barrel,its actually quite easy,just like building a model,the rebuild gasket set comes with pictures and instructions.Those carbs are known to have the base plate loosen
