Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Just bought a 1972 Skylark that needs tuning?
  #41 (permalink)
Old 11-14-2012, 08:29 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
It may be a good idea to check for vacuum leaks. Purchase a can of carb cleaner and spray around the base of the carb while the engine is running...make sure all vacuum lines are hooked up and not cracked. I have had a rochester 2bl carb with a warped base plate. See if that increases the idle speed or smooths out the idle...It's worth a try before you rebuild the carb.
