Just bought a 1972 Skylark that needs tuning? - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 11-14-2012, 11:33 PM
gearheadslife's Avatar
MentalMuffinMan
back up..
your bog.. can be from simple stuff.. from float level being wrong. to the vac. advance can being junk or stuck from lack of use..
start with the basics.. the carb adjusted wrong could be all thats needed to fix your problems..
get a motors manual for your years and start with basic tune up stuff first
  #47 (permalink)
Old 11-15-2012, 06:25 AM
Greg T's Avatar
www.krusinklassics.net
I don't see that we've determined it's actual bog rather thn a simple hesitation upon tip-in. A bog is s serious dead spot where the motor refuses to accelerate when the throttle is opened and the vehicle actually slows. A hsitation, however, is a quick blip that cures itself in a second and shows no symptoms again until the throttle is taken from idle to open. I think we should learn more about the symptom before throwing out a million cures for what we have yet to determine.
  #48 (permalink)
Old 11-15-2012, 06:39 AM
Ok so let me try and explain a little bit better what happens. When you push down the accelerator If you push It down a tad to much It bogs down and seems like the motors about to die. The car slows down a lot! You have to let off and slowly push It down to keep going. It seems to do It no matter what speed your going.
  #49 (permalink)
Old 11-15-2012, 06:59 AM
Greg T's Avatar
Are you able to cruise at hiway speeds okay, but not accelerate? Can you reach hiway speed easily if you don't give it too much throttle, or does it not want to really go that fast?
  #50 (permalink)
Old 11-15-2012, 01:55 PM
I can reach about 45 easily if i slowly accelerate. Thats all the faster Ive had a chance to get it up to though.
  #51 (permalink)
Old 11-15-2012, 04:11 PM
Greg T's Avatar
You may want to check for fuel delivery problems such as pinched line, plugged filter, or failing fuel pump.
  #52 (permalink)
Old 11-15-2012, 04:24 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Originally Posted by LATECH View Post
Bogging sounds more like fuel starvation to me, also sounds like it does OK when you feather down on the gas, so I would start at the carb.
Fuel delivery could be an issue, so you might want to check fuel pressure as well.
item number 93547 at HF
Could be a bad pump, pinched or collapsed suction line, or plugged strainer in the gas tank.
You can check pump health and strainer restriction with the gauge I mentioned before.
Fact is stranger than Fiction
  #53 (permalink)
Old 11-15-2012, 06:17 PM
Thank you for the info. This is what I had originally thought It was.
350, 455, buick, carb
1972 buick skylark. can i make a sheetmetal dash fairly cheaply and easily? jagarcia05 Body - Exterior 9 06-30-2009 09:39 PM
65 Skylark GS jeffyt Introduce Yourself 1 04-30-2007 11:43 AM
Skylark jnn-hllfld@yahoo.com Introduce Yourself 1 08-11-2006 07:45 PM
Skylark price Introduce Yourself 2 05-07-2006 02:22 PM
1972 Buick Skylark parting out classiccarprojects Body - Exterior 4 05-13-2002 10:17 PM
