Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Just Bought a Furnace Need Help with Chimney
Old 10-30-2006, 07:16 PM
smoke's Avatar
smoke smoke is offline
It should have a round or rectangler opening for the flue. Either way you should be able to get an adapter to round. Most oil furnaces have to go up thru the roof but if it has a power venter you can go sidewall or you can get a power venter for it but the cheapest most likely is to go up.
