Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Just bought a new compressor--how bad did I do?
Old 12-01-2007, 10:41 AM
oldred oldred is offline
As long as you are painting just a piece at a time it will probably work ok but that compressor is probably going to be humping trying to keep up so it WILL get hot. That means there is most likely going to be some water to deal with so you best plan on a good separator system and don't just hook a hose to the compressor, if you do you may end up spraying nearly as much water as paint. This has been covered a bunch of times so you could do a search and find out which way would be the best in your case to solve the problem before it happens, should not be at all hard to do nor expensive.
