Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Just bought a new compressor--how bad did I do?
Old 12-02-2007, 08:52 AM
oldred oldred is offline
Originally Posted by F&J
On that shear; I find it hard to believe that they would rate it at "up to 14 ga mild steel" That's just way too optimistic, or misleading.
That drier/regulator should help with some moisture.
As with anyone on a tight budget, you need to "work with what you got", and try to work around the limitations
Yep, 14 ga is up in plasma territory or even an Oxy/aceythlene torch with a stepped sheetmetal tip.
Also as for working on a tight budget it is sometimes tempting to just tell someone to get a bigger and better compressor, etc, but that is not always an option and I agree that "work with what you got" may be the only option sometimes, assuming the tool/tools can be made to work even if they are not optimal.
