just brain storming..need info - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2011, 08:22 AM
i was wondering.. can i put a 3.875 crank in a sbc 350. an still use 5.7 rods or would it be better to use 6.o rods. what kind of cid would it make at 0.30 over.
Old 08-31-2011, 08:47 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
That would make a 396 small block, the piston compression height would only be 1.062 and would require oil rail supports, the pin is into the oil ring groove. Use either rod, there's no appreciable H.P. difference either way.
Semper Fi
Old 08-31-2011, 10:53 AM
just brain storming.. need info
i have a fresh 350 4bolt what kind of build would be the best street motor. a 355cid 358cid or a 383cid. i have heard a lot about the 383 i don't want blowers or nos. just old fashion hp/tqe.
Brain Storming!! ? about valve sizes BourgD Hotrodding Basics 12 01-23-2009 05:55 PM
brain fart!!!!!!!!!!! bradykat Engine 7 03-19-2008 08:30 PM
The Brain THE BRAIN Introduce Yourself 2 05-31-2006 12:07 AM
Brain Fart! Pony Hotrodders' Lounge 1 11-25-2003 12:23 AM
Had a Brain Fart!!!! crshrmn3 Hotrodders' Lounge 5 11-07-2002 05:05 PM
