Just built 383 chevy but backfiring??
I just got the engine together to the point where I was able to connect the radiator and fill it with water so I could start it... well....... I found that the 3/8" hole below the water pump on the pass side is shooting water out of it. WTF?? I got the block from Summit and now I need to install a freeze plug or tap it for a pipe plug. Soooo back to the story, I also have a dead battery and so I tried jumping it but it had a slow crank but while it cranked it did backfire a couple of times. I removed the EGR and blocked it off but the hole in the manifold still needs to be plugged and I need to install a cap on the EGR port on the header. Will not having that plugged yet cause a backfire> I have a buddy who has the fittings so he can weld them so I can reinstall them. I rotated the Engine to the top of the compression stroke to TDC and installed the distributor to #1. Could I have set TDC 180deg out? I used my thumb to feel compression from the spark plug hole. How do you set timing?
Thanks,
Chuck
ps this is a 96 Chevy Express van (vortec)
