If your lower a-frames are not parallel to the ground (the ball joint is closer to the ground than the a-frame bushings), you can get trick springs, assuming this is a drag only car.
http://www.competitionengineering.co...?CatCode=10033 If the lower a-frames are parallel to the ground, you can get dropped spindles to lower the car another 2". http://www.heidts.com/index.cfm/page...rod/prd154.htm |
| 1934 chevy 1/2 front end | lohi | Suspension - Brakes - Steering | 5 | 08-31-2007 11:53 AM |
| Front end mock up shows some problems, cut n weld or frame shop? | Ripped | Body - Exterior | 9 | 11-26-2005 07:03 PM |
| Mustang II front end Question | horvath | Suspension - Brakes - Steering | 35 | 03-02-2003 04:08 PM |
| is there any front end alignment people out there? | IHAVECHEVYPARTS | Suspension - Brakes - Steering | 5 | 11-26-2002 07:10 PM |
| Tables of rear end and front end dimensions | willys36@aol.com | Transmission - Rearend | 1 | 08-21-2002 05:33 PM |
