Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - just cc'd the pistons and heads
Old 01-18-2013, 05:07 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
Originally Posted by jtz55 View Post
thanx for the calculations tech.thought might be a little higher so iam happy with close to 10-1 wont have to worry about detonation while cruising around on hot summer days in central il.F BIRD what if any experience do u have with comp. cam products such as springs ,roller rockers. do u have any other preferences like manley or isky.or would u stay with the same manufactuer as the cam?
i have use that exact cam in a BBC.. Buy the complete K kit and install exactly as instructed. Make sure you get the cam button end play correct. Make sure you verify cam to stroker connecting rod clearance. and verify VTP clearance.
Call comp cams if you want. They are there to help. They have premium beehive springs too for this, if you want.
Its a good cam makes great power. Set the lash -.004" cold.
The complete K- kit is a great way to go . K12-772-8 for that cam.
I like Scorpion roller rockers.
I have never used a Isky roller cam but would not hesitate to do so.
I like an use their flat tappet stuff. Its one of my go to preferences for
a flat tappet cam.
I have a Comp cam in my car now.
I think you have made a good choice. Post back on how you like this combo when you get it all done.
