Just finished a horse trailer - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2014, 07:59 PM
Just finished this 2-horse trailer for my dad. Been sitting around here for several years, but finally started on it at the end of April and sent it home a few weeks ago. Put new tires and spare on it, all new wiring for lights and brakes, rust removal and replacement (16 gauge steel--sucked to fabricate but awesome to weld because it doesn't warp very easily). Had to cut off and fabricate the inner and outer door bottoms because they were completely rotted out. Wanting some heavy duty industrial finishes, I also wanted to do some experimentation here and went all Mastercoat.
I sandblasted off all the rust, then treated bare spots with the Mastercoat Metal Prep and then gave it two coats of Silver and then two coats of AG2000 red.
I initially started with the AG111 red, did a test spray on the roof and it exploded into fish eyes. I called Pat and we tried several things and didn't fix it so I tried AG2000 red and sprayed out very nicely. So he sent out more of the 2000 so I could finish the job.
The AG2000 red is a single stage very high in solids. I reduced it ~25% and used just half a quart to get complete coverage on the first coat.
On the second coat I reduced it more and used ~1.5 quarts, spraying it on a little heavier than the first. Also used more because I was spraying the doors inside and out. So I sprayed an entire horse trailer and used about 2 quarts.
One thing I will say here is the AG2000 was extremely resilient to adverse and non-ideal situations and set ups. My dessicant got completely saturated before the spray was done, and I even saw water bubbling out of my air line by the gun, but never had a fish eye. There was even water in the bottom of the regulator (after the water trap and dessicant in my line). Of course this isn't ideal and after I changed out the dessicant I also added on my dessicant hose to finish out the job, but I was pretty surprised the paint didn't start telling me it didn't like the air I was giving it. It flowed out very well and no runs.
We then gave it a good test and took it on a 7.5 hr haul at 70 mph on the interstate from Michigan to Iowa, and then down a few miles of gravel roads and had no chips.
I'm not going to lie, this was a lot of trigger time and a lot of my time, and as happy as I was to get it out of my life, I was also sad to see it go because it looked damn good and I was quite pleased with my job However the most gratifying part was the look on my dad's face when he first saw it, I don't think he thought it would come out that well and honestly I didn't either.
ID:	159361   Click image for larger version
ID:	159369   Click image for larger version
ID:	159377   Click image for larger version
ID:	159385   Click image for larger version
Old 07-06-2014, 08:05 PM
Just some more pics of the finished product. I wanted to polish the trim but ran out of time.
ID:	159401   Click image for larger version
ID:	159409   Click image for larger version
ID:	159417   Click image for larger version
ID:	159425   Click image for larger version
Old 07-06-2014, 08:13 PM
These were the bottoms of the doors I redid.
ID:	159441   Click image for larger version
ID:	159449   Click image for larger version
ID:	159457   Click image for larger version
ID:	159465   Click image for larger version
Old 07-06-2014, 08:52 PM
Wiki Edits: 31
Looks good. They really don't need to look that good you know, there going to be full of crap and smelly after the first transport.. I finished my sisters horse trailer for her a few weeks ago.. She really just needed to replace it but the money wasn't there for that, so we bought the steel and re structured the frame, put new wood in the floor and rewired it. Still looks like a pile of trash, and we finished it the day before she needed to transport her horse to a clinic with it.
Old 07-06-2014, 09:57 PM
Of course it needs to look good; I did it for my dad. They really aren't full of crap and smelly. They make a pile of poo right at the back by the door and you scoop it up. I don't pull my horses around in a trash trailer, don't want the same for my dad either. He might sell this trailer as he might sell his horses. If he does sell, this will help with the value for sure.
Old 07-06-2014, 10:24 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
The trailer looks really good.. Might even help the horse run faster..
Sam
Old 07-06-2014, 11:04 PM
Wiki Edits: 31
Yea. I know where your coming from.. My sisters trailer is safe for transporting her horses, we just didn't do anything for exterior cosmetics. I wouldn't have signed off on something unsafe.. I wanted to redo the entire trailer over and make it really nice, but the condition of the trailer was cost prohibitive since it was not built to be taken apart. ( sandwiched plywood behind sheetmetal ) and the frame had badly rotten crossmembers that we had to replace, I used 2x3 tubing rather than the stamped C channel the factory used..... We didn't have time to put the mats down for first use in the trailer, so all the wood turned black in the rear. Pressure washed it, but it still stayed discolored.
I was joking about the crappy and smelly trailer... Actually your trailer is the first horse trailer I've ever seen taken back to basically better than new condition. Never seen one that old, that straight.
Old 07-07-2014, 03:08 PM
Pats55's Avatar
Good job glad your father was happy with it
Old 07-09-2014, 09:58 AM
put up or shut up
nice work. Now we just need to get microfibers for them clumsy horses.
Best option for horse trailer paint Lizer Body - Exterior 10 09-13-2012 10:22 AM
I finished my trailer project!! schnitz Hotrodders' Lounge 10 07-23-2007 10:26 AM
I'm finished IROC100 Hotrodders' Lounge 0 03-12-2006 08:51 PM
just finished bad68 Introduce Yourself 1 03-09-2006 05:20 PM
My sisters lowered Buick and Horse trailer from 1962. MARTINSR Hotrodders' Lounge 4 01-22-2006 06:37 PM
