Just got the coupe running! Video link - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2012, 08:28 PM
Slomotion34's Avatar
Last journal entry: Tunnel ram for the 454
Just wanted o post a quick video that I shot of the 34 Plymouth finally (after 5 years) running again. Engine is a .040 over 454 11:1 forged pistons, comp hyd roller (11-443-8). Tunnel ram with 2 Edelbrock 600's. Totally homebuilt.
http://www.youtube.com/watch?v=2il5o...&feature=g-upl
Old 06-27-2012, 05:47 AM
67Mustang Al.'s Avatar
You have a nice stretch of countryside there. Looking at your engine while you are heading up the road it looks and sounds silky smooth. Did you pay particular attention to the the dynamic balancing during your build. Sure has some pulling power from your video. What sort of octane do you need to have it run with 11.1 Very nice
Cheers
Al.
Old 06-30-2012, 01:56 PM
The engine was balanced before the rebuild... since the crank was only polished and he same rods were used, I only paid attention to matching the pistons. I am getting away with 93 octane (Timing is 18* initial and total advance comes in at 30*). No knocking or pinging, run-on, or any other signs of detonation, and the plugs look good. I only have about 400 miles on it. Very happy and surprised to not have any cooling issues either...even in stop and go 95* weather.
I couldn't be happier with the combination - the 294/300 adv duration knocks the dynamic compression down to usable levels with pump gas. It pulls harder than I expected. Now to tackle the traction issue and start on the body work. 8.5 mpg is what I figured out... hopefully get it a little higher with some tuning.
Old 06-30-2012, 05:18 PM
Great video!
Thanks for the ride. I really enjoyed it.
Old 07-01-2012, 06:07 AM
Hi . Thats impressive with 18 and no pinging. I had to drop my 347 back from 12 to 8 to knock out the pinging. I could have gone to 98 instead of 93 but 93 here is $6.25 a gallon. so 98 is not an option.
Sounds like you will have a trouble free engine there. With twin quads on your build i am guessing that a finely tuned engine thats loosened up after a good running in will give you around 12 mpg. Whats gas worth over there.
Cheers, safe rolling.
Al.
Old 07-01-2012, 07:02 AM
35WINDOW's Avatar
Last journal entry: Engine!
Very, very nice-you should be proud, you did a great Job, and it sounds wonderful!
4 link install video Tony@AirRideTech Suspension - Brakes - Steering 4 10-18-2011 06:24 AM
Posting a video link,, will it work????? Bad Rat Off-Topic 13 11-16-2006 03:50 PM
Looking For Coupe Video western star Hotrodders' Lounge 2 09-19-2006 09:42 PM
no limit 4 link video mobythevan Suspension - Brakes - Steering 0 12-12-2005 09:53 AM
Video of my truck running. camberbrandt Engine 13 07-10-2005 06:54 AM
