Just a little Confused - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2005, 11:14 PM
Cleaveland Heads
Ok I know there are 2v 4v heads and then Australian heads. But what does everybody mean buy open chambered heads and quenched heads? Which is better for which application?
Also I heard that Australian cleveland 2v heads are better for getting that power everyone wants. Is there a specific year of head to look for. I have friends in Australia that offered to give a hand finding some heads for me but I don't know what I should be looking for? Any help is always appreciated
Old 08-24-2005, 07:46 AM
larryblack's Avatar
Certified Lead Foot
The open chamber and quench head are describing the combustion chamber size. Open chambers had larger chambers and usually were on low compression engines. Quench heads are smaller chambers and were usually on higher compression performance engines.
You can use quench heads and dish pistons for more streetable compression and better flame travel. Many open chambered heads were quite prevalent on SMOG motors in the 70's.
Old 08-24-2005, 02:35 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Try and use flat top pistons on a street motor if you can get the comp ratio you want. Better flame travel than domes. Hg
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Confused by the oil pressure adryan16 Engine 0 05-01-2004 12:20 PM
Ok, Now I'm confused!?! HELP?!? JHayman2677 Engine 6 04-29-2004 07:22 AM
Confused And Alarmed... KULTULZ Hotrodders Site Suggestions and Help 3 01-19-2004 01:30 PM
Confused on horsepower rating olds37dude Engine 18 12-01-2003 12:45 AM
confused??? cranknrods Hotrodders' Lounge 7 08-11-2003 01:48 PM
