Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - just looking
Thread: just looking
Old 12-27-2006, 12:38 PM
brian0605's Avatar
brian0605 brian0605 is offline
mostly confused
Last journal entry:
ur in luck
Check out Larrys Body shop in Mobile. Go east on 10 to the D.I.P exit ( not the dauphin Island exit in theodore/tillmans corner) In case you don't know D.I.P stands for dauphin island parkway, and it's about a mile past the I-65N exit. Once you Get off on the D.I.P exit you will need to go north (left) and you will go about 1.5 to 2 miles,you will see Bishop state Southwest campus on your right, at the next light take a righton Duval st. and you're there just behind the gas station. Larry is the older one(HIPPIE) and keith is his son 37 or 38. Don't let the shop fool you. Yes it's a dump but they turn out some real show stoppers. Take a look at the pics I have posted. Larry did all the metal repair and fabrication and many years later after my father in law and I did much more restoration work, engine and trans install, overhaul rearend, Larry sprayed the final top coat of paint. It has been rearended once since the restoration was complete and he repaired that with spot repair and I dare you to tell me where the old paint is and the new begins!!!
