Is it just me or is it gravity - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-09-2006, 07:52 AM
powerrodsmike's Avatar
Wiki Edits: 161
Originally Posted by jimfulco
That stuff's medicinal, right?
That's what we used to say, anyway.
BE different....ACT normal.
  #17 (permalink)
Old 01-09-2006, 09:20 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Don't chy'all be usen dem dar fancy city wordens on me!
Dang gum city folk
(wish I knew how to type in "hair lip")
SR66
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
  #18 (permalink)
Old 01-09-2006, 12:54 PM
Last journal entry: PICTURE TEST
welding
Back to the program.....
What typ of welding???? stick????
When i worked in the weld shop guys would bring me files and screwdrivers to magnetize ( they used them to get chips out of holes on the assembly floor). I would rap the tool with a heavy wire and hook the ground to one end of the wire and the stinger to the other,set the welder to 100 amps DC/SP. hit it twice for about 5 seconds,,,,,, and BAM it was a magnate!!!!!!
Keith
  #19 (permalink)
Old 01-09-2006, 04:10 PM
Getting the cables looped around your work can sometimes play havoc with arc control due to electro magnetism.
  #20 (permalink)
Old 01-09-2006, 05:19 PM
Last journal entry: frame build
I actually hadn't done any welding when it happened, but I was using the MIG a couple days before. It doesn't have enough lead to wrap around the table. What I was doing, is cutting some 1" plate with the plasma cutter. Had it cranked to the max of 65a. I would normally use a torch for this, but didn't want to harden the steel because I was going to turn the cuttings.
UPDATE:The magnetisim seems to have left the table, but the hammer and punches will still stick on the wall. Makes it easy to store them, but they look like they haven't shaved for a week. Also, the CD player quit working.
  #21 (permalink)
Old 01-09-2006, 06:27 PM
Jeez That Was Close
Got to thinking about the CD player, so had to check. The breaker for that circuit was tripped. When I reset it, a little wisp of smoke and pop goes the circuit. A piece of steel had pinched the power cord on the side of the table and down on the leg there is a burn on the wire where it was shorting to the leg. Evidently made my own low grade electromagnet. Fortunatly I never got myself included in the circuit. Now all I got to do is figure out how to demagnetize everything.
Harbor frieghts gravity feed paint gun? zachscc Body - Exterior 12 01-09-2006 07:22 AM
gravity feed sand blasters RICHARD MORGAN Garage - Tools 12 11-15-2005 09:10 AM
Gravity vs Siphon jcclark Body - Exterior 5 03-18-2005 08:20 AM
Anyone ever used an "ATD" 6836 gravity feed spray gun? STATUTORY GRAPE Body - Exterior 2 12-02-2004 04:27 PM
?? Flushing Brake System Cliffrun2 Suspension - Brakes - Steering 9 03-12-2004 09:02 AM
