Is it just me or is it gravity - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2006, 05:57 PM
Last journal entry: frame build
Never had this happen before. Everything on my welding bench is now magnetized, appartently even the bench. Wasn't yesterday. Not all bad though, the grindings and filings make some neat patterns. Any ideas why and what I can do about it?
Old 01-08-2006, 06:01 PM
poncho62's Avatar
Wiki Edits: 5
Don't get a metal plate in your head....................
Honestly don't know what would cause this. I have a metal bench that I have welded on for years, never magnatized.
Old 01-08-2006, 06:15 PM
Wiki Edits: 31
take some welding scrap and stick it to the bottom of the bench, the scrap should take the magnatism, it does work.
Old 01-08-2006, 06:27 PM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
ive heard that everything including trees get magnitized around UFO's .... did you have any little green men come check out your garage overnight?
Old 01-08-2006, 06:40 PM
Only Green man around here is me. Got the flu
Old 01-08-2006, 07:24 PM
powerrodsmike's Avatar
Wiki Edits: 161
don't set your 8 track tapes on it. It will erase them. I know that when I weld while my work area is in a big pile of filings and grinding dust the induction field around the ground lead makes the filings arrange themselves into really cool patterns. Just looking at them can keep me occupied for hours and hours and hours an................
BE different....ACT normal.
Last edited by powerrodsmike; 01-08-2006 at 07:39 PM. Reason: needed to add some drool
Old 01-08-2006, 08:29 PM
46chevyfleetline's Avatar
Last journal entry: A few more
Don't sit your butt on it with your wallet in your back pocket or you'll be replacing your debit and credit cards cause you just messed up the magnetic strip. Cheers!!!!
Old 01-08-2006, 09:37 PM
61, do you have your welding cable around the bench?
Old 01-08-2006, 10:08 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
I want what YOUR smoking
definitely see how your leads are around the table you should try using a old speaker magnet and rub it on the table to reduce the magnetism built up in the table I dunno this is a new one to me
see if this helps I couldn't get a short cut to the page sorry
SR66
"SlowRide66"
"Illegitimis non carborundum"
Old 01-08-2006, 10:09 PM
73oldsman's Avatar
It's due to the hydomagnetic electrical impulses randomly transmitted and cross-transmitted through the pulse electrical energy emitted from the negative electrons colliding with the positive electrons in your welding cable, or something like that so I've been told. And yes, the '60's were good for me.
Old 01-08-2006, 10:56 PM
Wiki Edits: 161
[QUOTE=Rob Keller]I want what YOUR smoking
It should be YOU'RE. Like as in "you are", with an apostrophe in the place of the "a". "I want what you are smoking" . Sorry ,I couldn't resist. The smoke 's all gone. All I have left from those days is scorched lungs and some old Cheech and Chong records. I have always been easily amused. Momma said I was special. One time I had my wallet in my front pocket and BOTH welding leads were laying across my lap while I was welding. I had to get every atm and credit card that was in my pocket replaced. Come to think of it, my kids are kind of funny looking too. If you want to see some neat patterns take that old speaker magnet and rub it around on your TV screen. It will mess up the TV beyond repair but it sure makes some cool patterns before the screen goes away. Makes trails too. I think oldred pegged it with the wrapped lead thing. I gotta go fix my tinfoil pyramid hat now.
Old 01-08-2006, 11:16 PM
tenfords
It must be very dry there and the use of electrical equipment would definitely charge nearby metal objects. I would try hitting the bench with a heavy hammer which should discharge the juice. But first try putting a cat on the bench for an interesting pic. Speaking of metal benches does anyone have the plans for a good one, say about 3 feet by 5 or 6 feet.,,, thx fast ed
Old 01-09-2006, 12:07 AM
Rob Keller's Avatar
Wiki Edits: 38
powerrodmike
bnice i cld b talkin lik this here n use ur instead of your or you're ifinthe spellchekr dont get'er tha F it!! u no wha Imeen? take atokeholdthesmokeblowyoufinmind
speal u l8r
SR66
its 2 Am & no I dont smoke it no more got tired of waking up on the floor ..no thank you please it only make me sneeze and then i.....
"SlowRide66"
Old 01-09-2006, 01:18 AM
Wiki Edits: 161
Originally Posted by Rob Keller
powerrodmike
speal u l8r
SR66
ya bdde eye gno whadda ya meen. ur mkeg prphekt cince tu mee. c-kret k-oweds r finfun. Someone is gonna look at this and think it is a computer virus.I hope 61 puts the cat picture up soon I'm getting tired. I think I'll go home now.
Old 01-09-2006, 01:22 AM
That stuff's medicinal, right?
Harbor frieghts gravity feed paint gun? zachscc Body - Exterior 12 01-09-2006 07:22 AM
gravity feed sand blasters RICHARD MORGAN Garage - Tools 12 11-15-2005 09:10 AM
Gravity vs Siphon jcclark Body - Exterior 5 03-18-2005 08:20 AM
Anyone ever used an "ATD" 6836 gravity feed spray gun? STATUTORY GRAPE Body - Exterior 2 12-02-2004 04:27 PM
?? Flushing Brake System Cliffrun2 Suspension - Brakes - Steering 9 03-12-2004 09:02 AM
