The best way I have found for small block chebbies is the factory method.
Engine off # 1 tdc compression stroke(verify it is compression stroke-vital) #2. loosen both rockers on Cyl #1, pick either the intake or exh. valve to start tighten it down slowly while twisting the pushrod.When you feel a slight drag on the pushrod to twisting go 1 more complete turn.#. Do the other valve on this cylinder same way.Now rotate the engine 90 degrees in the normal direction of rotation with a breaker bar and socket.Now cyl. #8 is ready to be done in the same manner as number 1.Another 90 degrees and do cyl#4.90 more and do #3,90 more do #6, 90 degrees more do #5, 90 more do #7, 90 more do #2 and you are done and have rolled the engine over 2 times while adjusting your valves. This method will center the plunger in the lifter and if noise still remains it is not an adjustment problem. |
| ticking under no-load | mhamilton | Engine | 14 | 07-24-2006 02:48 PM |
| ticking small block | mhamilton | Engine | 10 | 07-02-2006 06:12 PM |
| ticking sound sbc | Chevy Hi-Po | Engine | 13 | 12-28-2005 12:02 PM |
| Mysterious Ticking | cutsupreme | Engine | 2 | 07-19-2004 12:53 PM |
| Ticking Noise | Jeff Christenson | Engine | 9 | 02-23-2003 07:17 PM |
